Front timing cover idler
kapri
Post by kapri » Sun Aug 09, 2020 7:57 pm
How do I remove the timing cover idler bearing without damaging the front cover ? An even bigger question are they still available ??
rebel alliance
Post by rebel alliance » Sun Aug 09, 2020 8:42 pm
Remove cover pull out stainless clip from the hole on top of the bearing place on a press and push bearing and core plug from the back be sure to support the front of the cover or you will crack it very easily...Burtons do the bearing i think
Post by scimjim » Sun Aug 09, 2020 8:48 pm
Yep, still available but about £50 IIRC 😬
rebel alliance
Post by rebel alliance » Sun Aug 09, 2020 8:49 pm
Or if you know a good welder do this
