Power steering pump bracket
Masterblaster
Post by Masterblaster » Sun Aug 09, 2020 2:12 pm
Hi all, I'm currently at the power steering pump stage , having delved into the box of parts I've found the rear bracket of the pump only fastens to the adjuster bolt on the back of the pump because I am short of a small tri holed bracket that bridges the other securing bolts would I be OK fabricating a bracket of sorts to replace the missing item?
I'm having the usual problems trying to re build a car someone else has taken apart and put most bits and bolts in a box , thanks in advance, Andrew
Post by gtcse8 » Mon Aug 10, 2020 6:06 pm
Hi Andrew
Where are you?.
I have lots of bits for the PAS system.
Which engine is it fitted to?.
Masterblaster
Post by Masterblaster » Tue Aug 11, 2020 7:39 pm
Hi, I'm in North East nr Saltburn by the sea , Essex engine, its the smaller bracket at the rear of the pump, cheers
Post by gtcse8 » Tue Aug 11, 2020 8:08 pm
Saltburn LOL.
Been up in your area loads in the past.
Always did North East Summer meetings.
Peter and I are old friends.
Will be at the storage units over the weekend if you can wait ??.
Masterblaster
Post by Masterblaster » Tue Aug 11, 2020 8:23 pm
Hi yes I can wait, plenty more jobs on the go with it, as always many thanks Andrew
