6A Kick down cable
John042
6A Kick down cable
Post by John042 » Fri Jul 31, 2020 10:11 am
Hi, just nearly finished a re-commissioning of a 1977 Scimitar 6A Auto. A bit of confusion over the kick down cable. Was disconnected by the previous owner. I seem to remember past posts on the subject, wrong cables etc? Anyway I've included a couple of pics of my layout. Basically if I adjust the cable to reach the carb' linkage, at idle there is a loop of inner cable not returning. Which on opening and closing the throttle will cause the linkage failing to return to idle. I've had the gearbox sump off for oil/filter and servo seals replacement and the mechanism seem to be working correctly. I don't think a shorter cable would work as the movement required within the gearbox is only about 3/4" to operate the valve and then would restrict full throttle at the carb' end. Any thoughts please? Cheers J C.
John042
6A Kick down cable
Post by John042 » Fri Jul 31, 2020 10:16 am
Sorry pics x 2 of kick down cable, carb' end.
6A Kick down cable
Post by AJL Electronics » Fri Jul 31, 2020 10:38 am
There is MEANT to be a loop at idle. You just adjust the cable until it just goes tight near WOT and that's it. If the throttle isn't returning, I can't see how it is down to the kickdown cable as it will be really slack at that point.
John042
6A Kick down cable
Post by John042 » Fri Jul 31, 2020 5:55 pm
Thanks AJL as I thought. However the kickdown cable on the return to idle did somehow formed a loop keeping the throttle open. Maybe a stronger return spring is required?
6A Kick down cable
Post by gtcse8 » Sat Aug 08, 2020 9:36 am
I can see you using a bolt to connect the cable.
Originally it was a clevis pin and split pin to prevent clamping of the cable end to the lever.
It HAS to be loose, your not clamping the cable too tight are you?.
TrevorG
6A Kick down cable
Post by TrevorG » Mon Aug 10, 2020 8:21 am
I think Mark has it, as the cable will try to kink if the bolt is tight..just add another nut and tighten the two together whilst bolt is loose in fitting.
