Refitting doors and windows
Thorpe
Post by Thorpe » Fri Jul 03, 2020 3:22 pm
Any guideance or tips would be helpful. I have removed the old metal and will soon be fixing in the new inserts. I have test fitted the doors and at this stage both sides are looking fine apart from the drivers door which kicks out at the bottom for the last 8 inches, is there an easy fix for this as i dont like the idea of cutting the door to pull it in a couple of mill and i dont think its to do with the hinges as two thirds of the door lines up nicely. Also what is the best sequance to refit the windows and do i need to remove the glass from the bottom window channel regulator or is it possiple to refit the glass and window closing unit as one?
Eddie
scimmy_man
Post by scimmy_man » Fri Jul 03, 2020 3:37 pm
on a GTC?
the body mould is wrong making the door stick out
best fixed when re painting
Thorpe
Post by Thorpe » Fri Jul 03, 2020 4:11 pm
its a 6a
Post by scimjim » Fri Jul 03, 2020 7:17 pm
AlMost all 6/8 series have that to a lesser or greater degree - door shimming will only get it so close and if you aren’t happy with that you need to cut it I’m afraid.
Post by DARK STAR » Fri Jul 03, 2020 8:27 pm
Could just be the (correct) seals are too thick ...
