Acellerator pedal removal ( in car )
kapri
Post by kapri » Thu Jun 25, 2020 9:03 pm
I'm about to take the accelerator pedal out of mine while still in the car . I've looked at the pasrt manual but can't see anything retaining the cross car through the pedal box bearings ? How do you disconnect , just pull it or ...?
Post by Coupe Racing » Thu Jun 25, 2020 9:14 pm
If you email me I can take pictures of the pedal box out of the car.
To be honest I believe in the long run it will be quicker if you remove yours to achieve what you are trying to do
Post by DARK STAR » Thu Jun 25, 2020 9:16 pm
I think there is a plastic clip holding it in (to the left of the right hand upright)
The manual illustration is not very clear.
Se6 Clutch 5.jpg (106.48 KiB) Viewed 397 times
DSCF2575 detail.jpg (399.25 KiB) Viewed 397 times
DSCF2576 detail.jpg (414.97 KiB) Viewed 397 times
Post by DARK STAR » Thu Jun 25, 2020 9:20 pm
Part 23 or perhaps 24.
If you turn it through 45 degrees I think it will pull through the hole.
The SS1 pedal box does this anyway.
Post by scimjim » Thu Jun 25, 2020 9:43 pm
Much simpler than the SS1 as there’s no outer plate to fight with. Just twist the plastic bushes through 45 degrees and the pedal will pull out.
kapri
Post by kapri » Fri Jun 26, 2020 6:14 pm
Excellent, thanks for all the info and photos ,much appreciated.
