The right radiator cap
Thomaswo
Post by Thomaswo » Wed May 27, 2020 1:14 pm
Does anybody know the right specification for this cap? GTE 6a from 1977. Is it 0,9 oder 1,0 bar? LBS 9 or LBS 15?
Post by scimjim » Wed May 27, 2020 6:07 pm
None of the above - standard for a 6a is 13psi (approx 0.9 bar).
Thomaswo
Post by Thomaswo » Wed May 27, 2020 7:08 pm
Thank you Jim, couldn’t find that information, my 6a had a 15 psi installed.
Post by scimjim » Wed May 27, 2020 7:35 pm
I googled the ford part number from the reliant parts manual, then checked by searching on here.
Thomaswo
Post by Thomaswo » Wed May 27, 2020 7:44 pm
That‘s a good hint :!:
Thomaswo
Post by Thomaswo » Wed May 27, 2020 8:00 pm
I googled the ford part no. now, but most of the links were wrong. Most caps are short reach (app. 24 mm height) but we need long reach (34 mm). Else it wont fit.
5eon
Post by 5eon » Mon Sep 21, 2020 8:31 pm
It might seem like a daft question but how is the coolant drawn back from the expansion tank on this year car, does the cap have some sort of two way arrangement?
Post by scimjim » Mon Sep 21, 2020 8:38 pm
on the 6 series, yes, the vacuum formed as the engine cools will draw fluid back from the expansion tank
Post by philhoward » Mon Sep 21, 2020 8:39 pm
Because the cap has 2 seals (most caps don’t).
Dennis Nicholas
Post by Dennis Nicholas » Mon Sep 21, 2020 11:23 pm
Beware that some caps with the correct part number at a supplier may be just the tiniest bit short so that the bottom seal does not seal on the housing......it baffled me for a while when I put a new one in......water gets pumped out into expansion tank and overflows.
Dennis
Dennis Nicholas(RSSOC)
Post by philhoward » Tue Sep 22, 2020 2:41 am
Dennis
I’d say that was a badly manufactured cap though, not the wrong cap. Which supplier so one can avoid, Dennis?
5eon
Post by 5eon » Tue Sep 22, 2020 9:14 am
Mine has the 'top' seal which sits on top of the housing and the lower one which sits down inside the housing Phil, the bottom one is sprung to maintain pressure so how does the coolant get drawn back?
Post by philhoward » Tue Sep 22, 2020 9:44 am
Post by philhoward » Tue Sep 22, 2020 9:47 am
I believe there's a one way valve in the cap which allows it to draw it back under the vacuum too but having never owned a 6/6a I can't confirm 100%
I think it was pointed out by someone else recently?
Scim8tar
Post by Scim8tar » Tue Sep 22, 2020 10:19 am
I think every spring pressure cap on any make of car of the era has the one way valve , even if the car doesn't have an expansion bottle.
Paul
