New shocks and springs recommendation please - going for Protech
lambo911
Post by lambo911 » Tue Mar 24, 2020 7:46 am
Hi All,
Now I'm going to be at home quote a bit I have my 78 SE6a in the garage and I am going to overhaul the suspension and clean up the underside.
I am going to fit a new set of shocks and springs all round and I would like to lower the car slightly, especially the front.
I saw an earlier thread about issues people had had with shocks and bushes wearing out prematurely but the thread never came to a clear conclusion on the best shocks to use.
Can anyone recommend a set of shocks with adjustable ride height and also what springs to use please?
Richard
Richard
1978 Scimitar SE6a MOD PS
1977 Scimitar SE6a MOD no PS
1986 Mercedes 190 2.3-16 Cosworth
1966 Jaguar s-type 3.8 MOD
Drury
Post by Drury » Tue Mar 24, 2020 9:39 am
My 6a is on AVOs.
Dennis Nicholas
Post by Dennis Nicholas » Tue Mar 24, 2020 11:53 pm
I was first person to work with PROTECH to get a set designed for my 6a (Rod Avon of AVO fame was their consultant) They supplied them with bushes fabricated from metalastic (Jaguar) ones which were internally bushed to fit the1/2 inch bolts and more importantly they were the correct 1 1/8 inch width to allow the Reliant spacers to be fitted INSIDE the brackets. (Some damper suppliers only recognise the bush width as 1 1/4 inch (the original 5 width before the Reliant modification).....look back through forum for extensive explanation.
I used 250 lbin front X 13.5 inch but on severe bumps the rubber built in bump stops were contacted so would have changed to 14 inch but car sold meanwhile as GTC became available at good price. There were 2 of 20mm = 1 3/4inch bump stops on front so maybe with just 1 it would not have bumped? The rears were 225 lbin X 12 inch with only 1 20mm rubber bump stop. Both were 2 1/4 inch interior diameter springs. Eye to eye fully open - front 390mm (15 3/8 inch) rear 451mm (17 3/4 inch).
Front spring seat was screwed up 3 1/8 inch to give 13 1/16 inches eye to eye under full load and standard setting of lower wishbones parallel to ground, so with 14 inch spring instead of 13.5 still plenty of room to adjust car lower (remember to reset castor and camber if you lower). Full load on front compressed spring by 4.83 inch and rear 3 inches
Rear was finally set at 16 1/4 inch eye to eye making chassis parallel to ground. (height to underside of chassis was 6 1/4 inch (195 x 70 x 14 tyres). There was 2 3/4 inches of thread at bottom to further lower car. The spring fully loaded was 9 inches seat to seat.
I have original (rough) drawings with some of my notes scribbled on if required, though I think I put them up on the forum
Adjustable spring seats and single damping valve adjuster control (as opposed to double - 1 for compressing up and 1 for release down)
Beautifully made with rounded ball ends in alloy.
This was all done back in mid/late 2007
Dennis
Dennis Nicholas(RSSOC)
adamwilkes
Post by adamwilkes » Wed Mar 25, 2020 7:46 am
Are non-adjustable coil-overs still available? I think I read that they are not, so I bought Spax adjustables (untested as car still on axle stands :W ) They fit without washer spacers on my 5a.
Adam Wilkes
lambo911
Post by lambo911 » Wed Mar 25, 2020 7:53 am
Thanks Dennis, I have emailed Protech for a price with the 250lb 14 inch front and 225lb 12 inch rear springs
Richard
lambo911
Post by lambo911 » Thu Mar 26, 2020 2:05 pm
I've decided to go with the Protech ones.
Front 15” open 10” x 300lbs
Rear 17” open 12 x 250lbs
Slightly different to the spec Dennis mentioned but after speaking to them this was what they recommended.
They are a good price too, quite a bit less than the AVOs.
Richard
lambo911
Post by lambo911 » Thu Jul 02, 2020 12:06 pm
Hi All, thought I should give an update now they are fitted.
The shocks look great and seem to be well made. i had no problems fitting them and the springs could be put on without needing to compress them.
I did have an issue with the 300lb front spring, the coils closed up quite a bit and I struggled to get a decent ride height. Protech swapped them for 350lb which sorted the problem however the ride is quite hard.
I think a 12" 300lb front spring rather than 10" 350lb would work better so I might try that when I get around to it.
I didn't have any issues with the rear shock specification.
Here is a picture, they did come with top hats, which aren't in the pic
Richard
Post by scimjim » Thu Jul 02, 2020 4:56 pm
There’s loads of threads on this already but in the one in the FAQ section (about the 5 series but equally applicable to 6/8 series), I said
scimjim wrote:
Mon Apr 30, 2012 10:14 pm
so something around 12/300 or 275 Front & 14/250 or 225 Rear would be a good starting point?
Dennis Nicholas
Post by Dennis Nicholas » Thu Jul 02, 2020 11:18 pm
As I said stick with 14 inch X 250 for front (13.5 found to be just a bit too short) Tried and tested on a GTE. Very surprised that Protech gave 10 inch to start with as I very quickly proved them to go coil bound with 250. 14 also allows plenty of height adjustment availability with the bottom spring seat.
My Protech were 15 3/8" (390mm) fully open eye centre to eye centre.
Car weight compressed 250 by about 2.4 inch. By definition a 250 spring will compress the same amount no matter what length it is i.e 250 lbs will compress the spring 1 inch whether it is a 10 inch, 13 3/8 inch or 14 inch.
Do not be confused by "pre-loading"......that is wrong terminology for "compressing the spring to get it on to the damper"...It is the weight of the car that accounts for the amount the spring compresses. If you have to compress the spring with say 50 pounds of pressure you DO NOT USE UP 50 pounds of the 250 rating.....once the full weight of the car is on the spring it will still compress the same amount as it would if the spring did not have to be "compressed to get it onto the damper"
Dennis
ScimiTom
Post by ScimiTom » Thu Jul 02, 2020 11:40 pm
Thanks for the update, Richard. It's handy as I'm about to order some too.
Dennis, would you suggest 14" x 250lbs for the rear as well then - or better with 12" x 250lbs (or even 225)? I'm thinking of a 5a, in my case.
Current: 'Boffin' (1971 SE5a)
Post by gtcse8 » Fri Jul 03, 2020 8:35 am
Tom Be very careful about fitting longer springs.
Reliant used longer springs at the rear as the shocker travel was longer too.
As they may have more coils wound on them to get the extra length they may go "Coil Bound" before they should, therefor losing suspension travel.
lambo911
Post by lambo911 » Fri Jul 03, 2020 9:49 am
Be careful because I think spring poundage takes into account the number of coils.
So a 300 10" spring with say 10 coils may have a spring thickness of 10mm
and a 300 12" spring with 12 coils may have a spring thickness of 8mm
It is better to have as long a spring as you can for comfort but of course on an adjustable shock the length you can use can be limited. For the Protech shocks, I think 12 on the front would be the max with 14 on the back.
A 5a is only 75kg lighter than a 6a so I don't think there would be a big difference in the poundage used between the to models
Richard
Post by DARK STAR » Fri Jul 03, 2020 8:25 pm
Best ever technical article on springs and shocks by Terry Rickard in current Slice.
I have always used and recommended Spax, Tony Shakeshaft is very helpful (and knowledgable)
PilotLight
Post by PilotLight » Fri Jul 03, 2020 8:58 pm
Richard,
Can we get a photo of the new stance and ride hight please?
I'm trying to figure this out for my 6a too.
Thanks,
Andy
Terry Rickard
Post by Terry Rickard » Fri Jul 03, 2020 9:25 pm
Thanks very much Chris (Dark Star) :)
