GTC 404 MOT Emissions
RonH
Has thanked: 21 times
Post by RonH » Fri Aug 16, 2019 9:27 pm
Just looked at the read outs on GTC 404 MOT issued two days ago.
CO 0.24 HC 217 off side and
CO 0.32 HC 75 nearside.
All marked as a pass.
The other comment made during the emissions test and noted on the paperwork is - Engine Oil temperature check: “coolant pipes were hot.”
Any suggestions or thoughts regarding these figures and comments greatly appreciated.
Also I’ve now found when turning the engine off I sometimes have a slight engine stutter/rumble.
The only thing that is different is that I put a couple of gallons of Morrisons petrol in for the short trip to MOT station rather than my usual Shell V power, plus a shot of Millers VSPe.
Will top up with the shell V power and Millers before setting off to Curbs tomorrow.
Ron
Been thanked: 436 times
Post by peter freeman » Sat Aug 17, 2019 8:36 am
Morrison's petrol turned my plugs red. COs are too low I aim for 2.5 the limit being 3.5 - why the comment about coolant pipes - was the engine too hot. I would expect the coolant pipes to get hot - that's what they are for
halfpenny
Post by halfpenny » Sat Aug 17, 2019 9:03 am
The mot tester was simply giving his reason for determining the engine was hot enough to perform the emissions check- I don't think he was indicating a fault.
Has thanked: 81 times
Been thanked: 212 times
Post by gtcse8 » Sat Aug 17, 2019 9:11 am
Will`s Middlebridge # 42 failed the emissions test first time, even though its a 2.9 Injection engine. :(
After debating weather to take it for a thrashing to clear the carbon out of the exhaust the tester told me to just turn the engine OFF and let it cool down a bit as the fan was cycling on and off while the rest of the testing was being done.
The car passed easily when checked 30min later. 8)
So heat MUST have some bearing on emissions. :?:
Although in all my years of testing V type engine cars I have Never had Both pipes checked. :!:
Dennis Nicholas
Has thanked: 64 times
Been thanked: 37 times
Post by Dennis Nicholas » Tue Aug 20, 2019 11:11 pm
My last figures. CO 0.06 (YES 0.06) and HC 87. Similar figures for past several years (now at 101,515 miles.)
But then I am running with the late Alan Deans gauzes and use Castrol Valvmaster + (octane boost of + 2. Usually on Shell unleaded 95. cause that is the cheapest, which I get at Trago Mills when going to monthly Noggin in S Devon. Occasionally use the odd supermarket or BP.
Did I also mention that I use SYNIONIC AFMT, at club discount, price, in all oil. :wink:
Dennis
Dennis Nicholas(RSSOC)
