Resistance is useless?
ard126k
Been thanked: 21 times
Post by ard126k » Tue Apr 23, 2019 12:16 am
I found this little chap sitting in the line from the voltage stabiliser behind the GTC dash. That red part is a coil of varnished wire which measures about 2 ohms. Question is, what would its purpose be? Taking it out to be photographed doesn't seem to have affected the instruments at all.
Alex.
1971 SE5 1977 SE6 1982 GTC
Has thanked: 50 times
Been thanked: 599 times
Post by philhoward » Tue Apr 23, 2019 6:15 am
I think it’s a suppressor to prevent/reduce the switching of the voltage stabiliser from generating EMF interference. .
Has thanked: 151 times
Been thanked: 27 times
Post by willholderogri » Tue Apr 23, 2019 6:35 am
Yes it's a choke /suppressor it will be In there to prevent electrical noise on your radio
Post by philhoward » Tue Apr 23, 2019 6:51 am
Choke - that’s the word I was after..
ard126k
Post by ard126k » Tue Apr 23, 2019 5:55 pm
There must have been a lot of interference, there's 2 more suppressors around the VS! Can't check just now as the radio's u/s.
