GTC 404 MOT electric advice needed
RonH
Has thanked: 21 times
Post by RonH » Fri Apr 19, 2019 8:39 pm
The MOT on GTC 404 ran out yesterday. :(
I haven’t taken it for the test as I have the problems listed below - all basically electrics.
The wipers have stopped working as well as the headlights. The wiper unit was fully refurbished around 6 years ago.
Both seem to have stopped working immediately following the whole front of the car as well as the new fitted bonnet were resprayed 4 months ago in December. Tried various fuses all seem fine.
Can’t get the full beam to work on one side and main beam lights not illuminating at all.
Any ideas greatly appreciated. Can’t believe it this hot Easter weekend and can’t go anywhere in a convertible.
If I can get these problems fixed tonight I’m hopeful that I can get it MOT’D tomorrow. :D
Has thanked: 185 times
Been thanked: 1263 times
Post by scimjim » Fri Apr 19, 2019 9:17 pm
Fuses can seem fine but not conduct - remove, clean (fuses and fuse box clips) and check for continuity as well as seeing if the end caps are tight. Check for power at the wiper and lights using the battery neutral. If that’s okay, suspect the earths.
RonH
Post by RonH » Fri Apr 19, 2019 9:32 pm
Cheers Jim
Will check all that you have mentioned.
jeff hoole
Has thanked: 17 times
Post by jeff hoole » Sat Apr 20, 2019 6:45 am
Check the relays up behind the glove box they control everything you have mentioned.
Jeff hoole
Present :- 2 x 5a 1 x 6a 2 x 6b a gtc & a 68 coupe
1983 380 sl r107. 1933 humber 16/60. E30 BMW 325i sport
Has thanked: 224 times
Been thanked: 52 times
Post by willholderogri » Sat Apr 20, 2019 7:18 am
I would start with the earth's on the headlights .put a temporary one in from the battery if this works .it may solve some of the other issues as well
Post by scimjim » Sat Apr 20, 2019 8:22 am
The ignition relay provides power to fuses that feed the electric windows, electric door mirrors, heater motors, front and rear wipers, so if they’ve all failed, suspect that relay.
As standard, the wiring diagram says that dipped beam (outer lights) aren’t relayed and the inner main beams aren’t relayed, only the outers - they are also paired from the fuse, so it must be a poor connection or earth if one is working and the other isn’t (assuming the bulb itself is good).
Post by Roger Pennington » Sun Apr 21, 2019 7:50 pm
Yes, assuming the wiring is as per the Se6a, the inner mains are unrelayed and the supply to them acts as the trigger current for the outer main beam relay, which is one of the 3 behind the glovebox.
RonH
Post by RonH » Sun Apr 21, 2019 9:22 pm
Today
Inner 5 3/4 inch mains not working. Outer 7 inch lights side light bulb fine. Outer 7 inch lights working. Flick to full beam via steering multi switch - only one 7 inch light lit. Found 3 relays behind glove box. Looks like they are piggy backed. See photo.
Has thanked: 79 times
Been thanked: 212 times
Post by gtcse8 » Sun Apr 21, 2019 9:28 pm
They been messed with Ron
Shouldn`t be piggybacked and the originals are Lucas "Barrel" type, the Ripca I have never heard of.
Have you checked and cleaned the fuses in the engine bay that are in the small black fuse box fastened to the slam panel ?
Has thanked: 375 times
Been thanked: 265 times
Post by Corky » Sun Apr 21, 2019 9:59 pm
They could be the relays I installed when I restored the car. I replaced the barrel relays with like for like modern versions (not piggy backed). That was about 8 years ago though, so could’ve been messed with since.
Been thanked: 123 times
Post by ScimmyMike » Sun Apr 21, 2019 10:03 pm
I found similar issues when rebuilding my 6b was the fuses on the front panel to right hand side of bonnet, bad contacts, had me baffled for a while, take a look at those, as others have said might look okay but not making proper contact, clean contact and fuse up and check that the fuse wiring is okay, might look good but the soldered connection to the fuse wire sometimes becomes effectively a dry joint
Post by scimjim » Sun Apr 21, 2019 10:04 pm
They’re not original relays - but that doesn’t matter.
Not sure what you mean by piggybacked? They share common brown and black wires as standard.
Post by Roger Pennington » Sun Apr 21, 2019 10:19 pm
Today
There should be three relays in that location - the "ignition" relay, the "main beam" relay, and the "aux lights" relay. As Mark says, they are normally round relays. What do you mean by "piggybacked"?
Post by gtcse8 » Sun Apr 21, 2019 10:42 pm
Steve has answered that question
RonH
Post by RonH » Mon Apr 22, 2019 12:02 am
I’ve carried out a basic check of the 4 fuses in the engine bay with a continuity tester (fuses taken out). One seemed a bit hit and miss so that was replaced. When I took the the glovebox out there are 3 relays as per picture and 3 inline fuses (possibly associated with radio/cd).
What I mean with piggy back relays is that I was expecting to see (to my mind) a “typical looking relay - a cube shaped block”. But all three relays look deeper- like two cubes stuck together. I didn’t get to investigate further as the sun was that bright I couldn’t see a thing. Also they are really well fastened down with nylon ties and set well back in the glove box. My guess is that they are Steve’s (original - modern relays so these replaced the original barrel relays). Unfortunately I can’t personally see me getting at or checking out these relays. No idea as yet why the wiper motor has stopped working.
On the positive side the smiths clock started to tick for the first time in 2 years.
