Random stuttering/cutting on way to work this morning
Diyhell
Has thanked: 96 times
Post by Diyhell » Mon Oct 15, 2018 10:50 am
Not looking forward to the 1hr journey home today (half motorway :shock: ) with the Essex engine randomly stuttering and losing power on the way in this morning.
Seems electrical (tried adding some manual choke but didn't seem to wholly resolve the issue) - had a quick check under the bonnet but nothing seems amiss.
Any thoughts?
SE6a needing lots of work...
demonbluedays
Has thanked: 21 times
Been thanked: 14 times
Post by demonbluedays » Mon Oct 15, 2018 11:43 am
Coil/dizzy maybe? Be my first poets of call
Tom "DemonBlueDays" Williams
1976 SE6 #141 "Mighty"
2009 Fox "King"
Former Owner Of
oilrag
Been thanked: 11 times
Post by oilrag » Mon Oct 15, 2018 11:50 am
A friend of mine had similar problem last week in his essex powered tvr3000m ,he struggled to my workshops and i multimeter checked all of the usual connections around coil/ dist etc ,nothing wrong,no loose or broken wires,then i saw his key ring,hanging from the ignition switch was half a pound of various metal,swinging in the breeze, so i removed ignition key from the bunch ,placed in lock and started engine,it idled happily ,a gentle tap on key caused a misfire .......the rotary switch at bottom of barrel was buggered,handily i had a new spare for my gtc ,swapped it over ,no misfire anymore and now just 3 keys on his key ring,not a jailors bunch.
Give it a try ,its a common issue on older cars ,my sons mk2 golf did same years ago,cutting out intermitantly under braking as his key bunch swung merrily :)
Hope this may help
G
1980 GTC : 1972 SE5A and a few more long gone but not forgotten. Ex Middlebridge Employee.(12/88-05/90) RSSOC 3140
Diyhell
Post by Diyhell » Mon Oct 15, 2018 12:32 pm
Both good calls - any other thoughts?
Been thanked: 385 times
Post by peter freeman » Mon Oct 15, 2018 12:48 pm
I think you have to find out if its electrical or fuel as a start - not easy if only happens on the move but the rev counter may be a guide as it will fall to zero pretty quickly if the spark dies whereas with a fuel problem it may well still indicate for a short while
Rev Light
Been thanked: 30 times
Post by Rev Light » Mon Oct 15, 2018 12:50 pm
What is you rev counter doing? If it is dropping to zero intermittently, it points to ignition circuit....all of it
SE5a 'Fancier'
Rev Light
Post by Rev Light » Mon Oct 15, 2018 12:51 pm
Doh! Peter got there first
SE5a 'Fancier'
Diyhell
Post by Diyhell » Mon Oct 15, 2018 2:41 pm
Ah, good point (joke somewhere there) about the rev counter. Which isn't connected up...! Will temporarily wire it in.
Diyhell
Post by Diyhell » Mon Oct 15, 2018 7:11 pm
Strangely all week on the return home. Either it was damp, but seems strange as it had an hour's drive to dry out, or my wiggle of wires sorted out.
On a random note, this morning the voltmeter was only showing charge around 12-13v. This evening it showed 14ish. Both with lights off and no other drain. Hmmm.
Has thanked: 50 times
Been thanked: 259 times
Post by AJL Electronics » Mon Oct 15, 2018 8:09 pm
It says ignition switch to me.
