New Member Lincs
rjudcsx
New Member Lincs
Post by rjudcsx » Thu Mar 05, 2020 5:46 pm
Hello ,just come back to the fold after a very long time away [1980s].Name is Richard and I live in Chapel St Leonards nr good old Skeggy. After a long time fighting myself I decided to take the plunge and buy a Scimitar again ; the time was right [ semi retired ,Scim prices going up , the wifes life membership of QVC ect]. I had kept an eye on the regular sites , and I found one that meet my list of preferances .A 1974 se 5a man /od SUL 139N in White with Black int . It appears to have been left dormant for some time following ,on initial inspection, some major work. [Respray ,stainless parts, engine work,rear axel work, Spax all around ,new rubbers etc etc] Due to a period of slumber prior to my purchase I am in the process of appraisal ,which has been a pleasant journey to date. Most telling issues to date are that the delivery man broke the gear stick [I know, I could not beleve it ]and I am having some difficulties sourcing a good secondhand one at a price commensurate with the pocket money I get ! Also she can be a devil to start [ man choke Weber conv] I have tried different combinations of choke no pumping ,choke and a couple of pumps engine spins then when I release key it will some times fire up and run very well [new pet has been put in tank ] ,must look at the electrics it has some form of immob fitted . The journey continues , sorry for the rambling first post Richard.
New Member Lincs
Post by scimjim » Thu Mar 05, 2020 5:54 pm
Welcome :D
IanC
New Member Lincs
Post by IanC » Thu Mar 05, 2020 6:55 pm
Hi Richard,
There's a SE5a gearlever for sale in the Facebook 'Reliant Scimitar Parts Group'
Cheers, Ian
Current : SE5a 4spd auto , SS1 1.9CVH
New Member Lincs
Post by philhoward » Thu Mar 05, 2020 7:01 pm
Welcome :D
Firing only when you release the key sounds like the ignition switch contact block; try not turning the hard over to the start position (just enough to engage the starter) and see if it’s any better. New contact blocks are available.
rjudcsx
New Member Lincs
Post by rjudcsx » Thu Mar 05, 2020 7:35 pm
Hi IAN Thankyou for your response to my broken gear stick nightmare; I am not on FB however the photos on your link show a stick that might do the trick, however looking at my workshop manuel [Autobooks page 65 and page 67 ] I believe I need one from a later type box which is a hybrid of Ford gearing and Reliant casing /shift ? I would appreciate any guidance on this from others who are in the know. Thanks Richard.
rjudcsx
New Member Lincs
Post by rjudcsx » Thu Mar 05, 2020 9:49 pm
Thankyou Phil for the advice ,will have a go tomorrow .Any ideas re gear stick would be a real bonus Richard.
Geraint SabreGTCse5
New Member Lincs
Post by Geraint SabreGTCse5 » Fri Mar 06, 2020 10:07 am
the one listed on face book is from a very early 5 gearbox, it won't fit if you have a remote gearlever which would be regarded as the later box. The scimitar dealers may have one I know GW had some secondhand ones but they might seem expensive to some. If you have a later box I will have a spare gear stick somewhere.
Geraint
rjudcsx
New Member Lincs
Post by rjudcsx » Fri Mar 06, 2020 12:56 pm
Thank you , it is a late 5a [ Aug 1974 ]. I have contacted some traders ,however, they do not appear to have one on stock / stick list [GW did say they would have a look in the vaults for a s/hand one .Im to ring back in a week ] Therefore , if you can find one I would be over the moon .I have put a post on the 5 /5a site and members have been very helpful, apparently a common problem that some have solved by a sleeve /weld may have to go down that road if no other solution comes up in the next few weeks ,the car is SORN at present . Richard.
Return to “Introductions”
