SCISSOR LIFT FOR <£1K 2,268kg
Links to Scimitar-related ebay items and other sales sites
Moderators: scimjim, Roger Pennington, philhoward, Lukeyboy46, erikscimitardemon, Terry Rickard
Been thanked: 120 times
Post by ScimmyMike » Wed Jun 05, 2019 12:20 pm
Don't know whether anyone may be interested but costco have a scissor lift for £1k delivered, it's basic but well up to handling a scimitar's weight
You'll of course either need to be a member or know one to be able to purchase it.
Stephenl
Post by Stephenl » Wed Jun 05, 2019 11:40 pm
I've been looking at something similar which lifts up the front two wheels only, you drive onto them and then a hydralic pump lifts two ramps. A guy in one of the classic car magazines has one and lifted his scimitar with it and then put a trolley jack under the rear axle to get all 4 wheels off the ground (or it might have been the reverse order!). I was sorely tempted but as I'm in the US it would have been painful to ship.
Is this a good deal?
Costco US have this lift too, for $999, which is about £780, even better.
Do you have one Mike?
'69 SE5
Benc
Has thanked: 86 times
Been thanked: 38 times
Post by Benc » Sun Jun 16, 2019 11:26 am
This one looks good for a low height garage and only £160 more than the scissor lift above.
https://www.automotechservices.co.uk/pr ... post-lift/
old bean
Post by old bean » Sun Jun 16, 2019 11:50 pm
A jack and four axle stands works out a lot cheaper.
scimitargtc
Been thanked: 21 times
Post by scimitargtc » Mon Jun 17, 2019 9:50 am
Interesting. i had 2sets of the hydraulic ramps to get all 4 wheels up, replaced with @ scissor lift from bhrepairs delivered the Costco one compare seems lightweight, mine weighs 450kg as my left foot will attest to but it’s great with a 48 inch lift height lifts my 6 a with ease
Has thanked: 31 times
Been thanked: 47 times
Post by Alan SS1 » Mon Jun 17, 2019 1:01 pm
that would be neat! if the switch gear could fit on either side of lifting post as 'just too wide' for the garage :-(
and no I'm not cutting a hole in the wall to access the switch.
fylde69
Post by fylde69 » Sun Jul 28, 2019 9:25 am
same place also do a narrow version.....https://www.automotechservices.co.uk/pr ... post-lift/
craig
Post by ScimmyMike » Tue Jul 30, 2019 8:46 pm
craig
Both of course would require bolting down to a decent thickness of concrete, most typical prefab type garage's floor slabs wouldn't be suitable to take the bolts required I'd say unless you know the specification and thickness of the concrete used
td99
Has thanked: 17 times
Post by td99 » Tue Jul 30, 2019 8:59 pm
But if one has a low ceiling it would not be difficult to make reinforcing straps/bars to column tops to ensure stability.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
scimitargtc
Post by scimitargtc » Tue Jul 30, 2019 9:03 pm
Scissor lifts don't need bolting down in fact mine is designed to be mobile I did have a friend dig me a 150mm slab outside 1 of my garages so I can fully liftvandvavoid the door frame
Post by Alan SS1 » Fri Aug 02, 2019 12:39 pm
I did consider the TWO post lift and got 'worried' about the strength of the floor , actually couldn't see if there was a spec given on data sheet for the floor?
I guess it would be prudent to fix the the walls for 'fore-n-aft' rather than ceiling?? , but what to do to stop the tops folding in? as pretty sure the cross member shown is only to cover the drive system?
couple of sections of RSJ made into an 'H' pattern would work?
also considered that it would take up too much room, even the narrow/low version :-(
and would I really use it enough to get past the prying eyes of SWAMBO, it just 'might' be obvious? :wink:
Return to “Ebay and other Sales Links”
