coupe rear axle
Moderators: scimjim, Roger Pennington, philhoward, Lukeyboy46, erikscimitardemon, Terry Rickard
april2colin
coupe rear axle
Post by april2colin » Tue Aug 06, 2019 8:27 pm
Hi Guys. Has anyone got a good rear axle for a v6 coupe? Help will travel. Cheers Phil D.
briankenyon
coupe rear axle
Post by briankenyon » Fri Aug 16, 2019 12:55 pm
Hi.
I've got a early se5 axle if interested
april2colin
coupe rear axle
Post by april2colin » Tue Aug 27, 2019 10:03 am
Hi there. Thanks for your reply. Sorry for the slow response but been busy. Will this fit and is it the right ratio and is it quiet ? If so then I'm very interested. Thanks again. Cheers Phil D.
briankenyon
coupe rear axle
Post by briankenyon » Tue Aug 27, 2019 12:51 pm
Sorry it's sold
Try qrg at kettering
Regards brian
april2colin
coupe rear axle
Post by april2colin » Tue Aug 27, 2019 8:02 pm
Ok Brian. I'll keep trying. Cheers Phil D.
briankenyon
coupe rear axle
Post by briankenyon » Wed Aug 28, 2019 2:35 pm
Hi Phil
Spoke to Nigel at QRG this morning and I can confirm he has a coupe axle for sale
april2colin
coupe rear axle
Post by april2colin » Wed Aug 28, 2019 5:54 pm
Hi guys. I did the same this morning. He must think there's something going on. I'll have to measure mine to make sure. Thanks for that Brian. Cheers Phil D.
coupe rear axle
Post by gtcse8 » Thu Aug 29, 2019 8:08 am
Phil what is wrong with yours?.
There are a lot of different ratios for the Coupe out there, I have at least Two for spares.
april2colin
coupe rear axle
Post by april2colin » Thu Aug 29, 2019 7:15 pm
Hi there. My axle howls like a monkey with it's nuts in a grinder. I can check the ratio (v6 overdrive ) Nigel says there is more than one width of axle. seems strange More confusion. I'd be grateful for any further info. Holdup....my book says 3.58:1 Cheers Phil D.
coupe rear axle
Post by gtcse8 » Thu Aug 29, 2019 7:24 pm
NOT as far as I know??.
Will have a look at the ratios I have and get back to you.
coupe rear axle
Post by scimjim » Thu Aug 29, 2019 7:45 pm
Presumably he means there are two widths of 7HA - SE4 and very early SE5?
coupe rear axle
Post by gtcse8 » Thu Aug 29, 2019 7:50 pm
Possibly Jim
But it was stated for a Coupe I presume ?
april2colin
coupe rear axle
Post by april2colin » Thu Aug 29, 2019 9:02 pm
Hi guys. Your help is much appreciated. Yes it's definately a v6 coupe with o/d. The ratio that I quoted is in my copy of the workshop manual. Cheers Phil D.
coupe rear axle
Post by peter freeman » Thu Aug 29, 2019 9:16 pm
5 different ratios according to my list
chrisgallacher
coupe rear axle
Post by chrisgallacher » Thu Aug 29, 2019 9:35 pm
The very early Coupe 7HA axle was, I believe, the same width as the slightly narrower Sabre Six axle.
Early in the Coupe's life this was changed to the somewhat wider 7HA axle (about an inch, maybe an inch and a half, wider? Certainly not very much), but I'm not clear if this coincided with the change from the Sabre-type leading/trailing arm arrangement of the first 59 cars to the twin trailing arm & Watts linkage design of the subsequent Coupes. Or did it coincide with the change from the S6 to the V6 engine after 297 cars? Anyone know for sure?
I have a feeling it may have been at the latter point, because other front and rear suspension mods including changing the design of the rear twin trailing arms was done at this time. Don Pither talks a bit about this in TSAIF, p88.
Chris Gallacher
RSSOC Rally Secretary
rally.secretary@rssoc.co.uk
Locked
