Essex Timing gear
Cars and Parts Wanted
Moderators: scimjim, erikscimitardemon, Lukeyboy46, Roger Pennington, philhoward, Terry Rickard
Steve_S
Essex Timing gear
Post by Steve_S » Sun Jun 02, 2019 8:08 pm
Wanted an Essex timing gear not the full fiber one an alloy one would be ideal but ill settle for the fiber one with the cast center if anybodys got a spare there not wanting
Has thanked: 128 times
Been thanked: 134 times
Essex Timing gear
Post by b.c.flat hat » Sun Jun 02, 2019 8:42 pm
I'd advise defo not to fit anything other than alloy or steel. The Essex is an "interference" engine, if the cam stops working the pistons do hit the valves which is why Ford modified the cam driven gear three times to try and extend the life of it.
Geraint SabreGTCse5
Essex Timing gear
Post by Geraint SabreGTCse5 » Sun Jun 02, 2019 8:58 pm
I have a steel and fibre one here I have just taken off a car to replace with an all alloy one ....if interested pm me
I would fit an all steel or alloy one myself ... oh I have :D
Geraint
Sabre ti, se5, GTC, 6b.......
Has thanked: 91 times
Been thanked: 143 times
Essex Timing gear
Post by reliant-reviver » Mon Jun 03, 2019 2:19 pm
The wheels are in motion with the next batch of alloy gear sets as previously supplied.
But other than "later this summer" I can't really say when they will be available.
Price will of course be keener than any other current offerings.
1969SE5
Essex Timing gear
Post by 1969SE5 » Thu Jul 18, 2019 3:32 pm
count me in for alloy gears if we have another batch offering, i somehow missed out last time, must have missed a posting or something. cheers.
Essex Timing gear
Post by reliant-reviver » Thu Jul 18, 2019 6:33 pm
Should be shipping via airfreight any day now so may well be able to offer them for collection from Curborough .
1969SE5
Essex Timing gear
Post by 1969SE5 » Fri Aug 02, 2019 4:21 pm
chaps, ar both gears replaced when eliminating the fibre one ? then is it alloy large and steel small ? or both alloy ? cheers
Essex Timing gear
Post by reliant-reviver » Fri Aug 02, 2019 4:51 pm
Large one is alloy, small one is steel. Possible to replace only the large wheel provided the teeth are of the same form as original and will mesh correctly.
Actually meant to post something up about these today as I have been liaising with the manufacturer over a minor production issue with the crank gears. The short of it is unfortunately a delay of around 40 days on the original time scale. So sadly I am not going to be able to offer these before Curborough.
1969SE5
Essex Timing gear
Post by 1969SE5 » Fri Aug 02, 2019 5:02 pm
do we have any rough idea on costs ? cheers
Has thanked: 59 times
Been thanked: 626 times
Essex Timing gear
Post by philhoward » Fri Aug 02, 2019 5:22 pm
If both gears are supplied, then you can be sure they're the revised form angle so unlikely to match your existing gear.
If one gear is supplied, then it should be the original Ford form.
Essex Timing gear
Post by reliant-reviver » Thu Aug 29, 2019 2:27 pm
Quick note to say the timing gears are due to land next week. Will post up full details and "offering" in due course once through customs and available for purchase.
Return to “Wanted”
