Rat Rod (running)
Rat Rod (really broken)
Post by philhoward » Fri Sep 25, 2020 4:56 pm
Gillsfan wrote:
Fri Sep 25, 2020 4:48 pm
sorry I can't seem to load videos to scimitar web.
You can't - but you can add Youtube links (and if in the right format - Jim did a "How To" - they can be embedded).
Post by scimjim » Fri Sep 25, 2020 5:10 pm
When you say both 3 and 6 have a spark, is that with each plug removed and tested, or a spare plug attached?
Post by scimjim » Fri Sep 25, 2020 5:14 pm
Ignore my last - sort the variable timing first. That can only be the dizzy at fault.
Gillsfan
Post by Gillsfan » Sat Sep 26, 2020 2:05 pm
Dizzy is off, following some advice of Facebook I've checked the shear pin, which seems fine. Vacuum advance also seems ok, as well as the weights.
Videos on the Facebook thread here.
https://m.facebook.com/groups/510232164 ... 0040846427
1969 SE 5 Manual O/D Rat Rod
Gillsfan
Post by Gillsfan » Sat Sep 26, 2020 2:18 pm
The one thing I did find was that one I put the plate back on the lever for the vac advance was a bit low and the plate could move. I'm not sure if I induced that fault taking it apart and putting it back together or it was already there.
Gillsfan
Rat Rod (might be fixed?)
Post by Gillsfan » Sat Sep 26, 2020 4:57 pm
I seem to of got somewhere. Retimed after refitting the dizzy. It ran and revved without backfiring, checked timing and it had moved slightly adjusted it back and whilst doing it noticed it move as I put the ratchet on. After messing about and scratching our heads, we have worked out (we think)that the vacuum hose isn't in its elbows far enough and it's getting knocked/moving and affecting the timing. Additional checking plugs revealed that they aren't in good shape, the spark from number 6 was very weak. New plug in and 6 is now firing correctly. The gaps were wrong on all of them and moving the plug from 3 to 5 moved the fault. So new plugs and longer vacuum hose and see if that improves things. I've also found a possible leak from the master cylinder to the servo, I may have found the braking problem as well (fingers crossed).
Post by Coupe Racing » Sat Sep 26, 2020 5:05 pm
If your timing is moving then check the length of the securing bolt as it could be bottoming out in the block
Post by gtcse8 » Sat Sep 26, 2020 5:16 pm
Which "Shear pin" is this Steve??.
After working on Essex engines for over 35 years I have never come across such a part :shock:
Gillsfan
Post by Gillsfan » Sat Sep 26, 2020 5:52 pm
I'm reasonable confident that the dizzy isn't moving, but I will double check it. Thank you
Gillsfan
Post by Gillsfan » Sat Sep 26, 2020 5:55 pm
I think it was the roll pin that was being referred to. That's what I took it to be.
Post by gtcse8 » Sat Sep 26, 2020 6:35 pm
Hardened spring steel roll pin :o
The gear is also pressed onto the shaft :o
I have had to destroy the cast iron gear in the past to rebuild dizzies :o
WTF I give up :bh
Gillsfan
Rat Rod (mobile timing)
Post by Gillsfan » Wed Sep 30, 2020 3:24 pm
I've fitted the new plugs and vac advance pipe. The timing is moving. I've set it several times now and after a rev/run the timing has moved. I took the dizzy out and tried the old dizzy(points) I could get it to fire, I turned it over with the cap off to try and watch the points working. I melted the points, I turned it over a few times and it resulted in smoke and a small flame 🔥. So I tried in desperation swapping the electronic ignition to the old dizzy. It fired straight up and I set the timinh, a bit of a rev and the timing has moved again. I marked the position of the dizzy and I'm confident it's not moving. Arrrrghhh help.
Post by philhoward » Wed Sep 30, 2020 3:28 pm
Is it still able to move spring loaded a few degrees? And more importantly move back?
Post by philhoward » Wed Sep 30, 2020 3:29 pm
“It” being the rotor arm and shaft.
Gillsfan
Post by Gillsfan » Wed Sep 30, 2020 4:40 pm
Phil yes 'it' will move then spring back.
