Rat Rod (running)
Rat Rod (really broken)
Post by Old and Slow » Tue Sep 15, 2020 10:16 pm
IIRC there's been issues with dodgy dizzy caps - if you have a new one it could be a problem, but it wouldn't be just one bank misfiring.
The oily plugs might suggest a head gasket problem - water leak - is the radiator cap blowing at all? A compression test might help check for leaks.
Post by philhoward » Wed Sep 16, 2020 5:32 am
A loose/failing inlet manifold gasket would also give similar symptoms as it’s trying to keep air, water and oil apart.
Gillsfan
Post by Gillsfan » Wed Sep 16, 2020 9:35 pm
Right, I've been out carrying out some investigation aided and abetted by Richie.
First, we pressured the cooling system and identified a couple of leaks/weeps, no rectified.
I put new spark plugs in (I happen to have a set) and WD40 (well 3 in 1) sprayed around the inlet manifold. No change to engine note.
Inlet manifold bolts check torqued 3 of the took 1/4 if a turn by nothing significant. None of them over-torqued.
Carb off and checked over, no issues. Just for you Phil the gauze is in as good condition as the day I made them :wink:
Inlet manifold off and I think we have a winner. In our opinion there is evidence of oil/water getting where it shouldn't and the passenger side looked worse than the drivers.
New gaskets already ordered from burton power, oil flush and change will be done as we spilt some water into the engine when we lifted the manifold off.
1969 SE 5 Manual O/D Rat Rod
Post by philhoward » Wed Sep 16, 2020 9:40 pm
Cheers for that Steve - and glad another of my hunches was closer (manifold gasket).
Post by AJL Electronics » Wed Sep 16, 2020 9:51 pm
Oil isn't much use for hunting gasket failure. The method behind it is to supply the engine with extra fuel that it wasn't expecting via the air leakage point. For that reason it has to be volatile, so Water Dispersant or thin oil is not much use as it is difficult to ignite. I use brake cleaner, but propane from a blowlamp would work too. The key is to only direct it at the suspect areas and not allow it to be sucked in through the air cleaner route. The engine note will change when it starts to ingest the extra fuel.
Will Yarrow
Post by Will Yarrow » Thu Sep 17, 2020 1:31 am
Wd40 has allways worked for me, I don't mind useing brake cleaner or contact cleaner, even carb cleaner at a push, but I'm reluctant to recomend it, just in case.
Post by Coupe Racing » Thu Sep 17, 2020 4:21 am
Mine too
Post by willholderogri » Thu Sep 17, 2020 7:44 am
what did you pressurise the system with and what pressure did you use as a max ? need to check mine
Post by Old and Slow » Thu Sep 17, 2020 8:59 am
Good to hear you are on the right path; well done - fingers crossed it solves all the issues.
Gillsfan
Post by Gillsfan » Thu Sep 17, 2020 12:02 pm
Thank you all for the advice and encouragement. My trip at the weekend has been cancelled, so I'm hoping to get her running again over the weekend. I have inlet manifold, rocker cover ,thermostat housing, carb gasket and carb top lid gaskets on order as well as antifreeze and coolant flush. new oil and engine flush are reserved for collection. Have i forgotten anything?
Gillsfan
Post by Gillsfan » Thu Sep 17, 2020 12:05 pm
I use one of these, I managed to pick one up cheap a few years ago. i can't remember what pressure we tested to, I was expecting a leak so when we got on after a few pumps i was happy and fixed the leak.
pressure test.jpg (63.92 KiB) Viewed 328 times
Post by scimjim » Thu Sep 17, 2020 12:11 pm
hylomar and oil filter.
Gillsfan
Post by Gillsfan » Thu Sep 17, 2020 12:30 pm
Roger, ordering some now. where am i putting the Hylomar? I 'm assuming inlet manifold gasket but where exactly?
Post by gtcse8 » Thu Sep 17, 2020 12:33 pm
In the bottom of the Valley, where the Cork inserts are fitted.
If the gasket is just a plain on, rather than having a screen printed Goo round the openings it won`t harm it to just put a bit round them.
Post by scimjim » Thu Sep 17, 2020 12:40 pm
I use hylomar on one side (the rocker cover side) of the rocker cover gaskets to keep them in place as you fit. Both sides of stat gasket and as Mark says, the cork bit front and rear of the inlet manifold and around the waterways. Put it on as thin as possible and allow to dry before fitting.
