Insanity
Bitterend
Insanity
Post by Bitterend » Sun Oct 18, 2020 1:24 am
OK.
I am currently in the process of doing a drawing for the caliper mounting. This I have to reverse engineer as I dont have a manufacturers drawing for the calliper. Brembo on the other hand are brilliant with data on the stuff they produce, which is how I managed to find the disks.
So far I have got the distance from the face of the axle casing where the bearing is to the face of the mounting lugs on the calliper bracket. tomorow I measure from centre of the drive shaft to the centre line of the mounting bolts on the carrier and then make a template to check it all.
Monday, all things beig equal is off down to the steel stockholders to by a chunk of flat bar and machine it up.
As this is for a braking system I will machine it from a solid rather than fabricate something.
Unfortunatly I could not find anything shorter than 40mm. 30mm would have been really good and saved that 3mm step in. Ho-Hum... cant have it all!
https://www.bremboparts.com/europe/en The disks are for a Kia carens 08.9466.10
I WILL STRESS this rear disk conversion is being done along with a front brake upgrade, bigger disks and 4 pot callipers with larger pistons. I may have to add a bias valve when I test it.
adamwilkes
Insanity
Post by adamwilkes » Sun Oct 18, 2020 8:29 am
I like your thinking - a whole-system redesign rather than a piece-by-piece effort. Great work - looking forward to the next post!
Adam Wilkes
Bitterend
Insanity
Post by Bitterend » Sun Oct 18, 2020 9:48 pm
I have read about other conversions done elswhere and also on here. MikeyBikey has also been a great help. He used Rover disks on his conversion and had to get some machining done.
It is much easier to avoid some of the pitfalls by taking notice of the problems encountered by others and also their experiences. I did do a bias calculation, but I am a considerable amount of data short so it is only a ball-park figure. One of the biggest unknowns is the transfer of weight from rear to front when braking, In road going cars manufacturers traditionally used err on the conservative side and have the fronts lock up way before the back. ABS systems on modern cars have now solved that problem.
In the calculations I have done I am trying to frmain on the conservative side with a 70% bias to the front.
I hope I have the sums right. :!: but within that there was a considerable amount of estimating, particularly regarding weights.
