Reliant Scimitar SE6B
Terry Rickard
Post by Terry Rickard » Tue Sep 08, 2020 8:59 pm
Hypoid SAE 80 gear oil - GL4 spec
should take about 2.8 litres or 5 pints
Last edited by Terry Rickard on Wed Sep 09, 2020 12:12 am, edited 1 time in total.
jimmyo06
Post by jimmyo06 » Tue Sep 08, 2020 9:19 pm
Thanks Terry 😏
jimmyo06
Post by jimmyo06 » Tue Sep 08, 2020 9:20 pm
Surely they would have used a gearbox oil ☹️
I am calling them tomorrow to find out😡
Post by efi_sprintgte » Tue Sep 08, 2020 9:37 pm
jimmyo06 wrote:
Sun Sep 06, 2020 10:20 pm
Gearbox was drained of oil,remove filters & clean , no trace of materials,replace filters refill with 20/50 oil 24.8.2020.
I’m getting confused, you stated “they” didn’t use gearbox oil.
Post by scimjim » Tue Sep 08, 2020 9:59 pm
As Phil alluded to above, MG specified a 20/50 engine oil in their overdrive, so someone used to working on MGs May have just filled it without checking.
Post by scimjim » Tue Sep 08, 2020 10:01 pm
EP90 (edit EP80 - 90 is for the diff) would have been specified originally but a modern multi grade 80W90 is much better for it.
Terry Rickard
Post by Terry Rickard » Wed Sep 09, 2020 12:03 am
EP90 is for axle. EP80 for gearbox and gearbox with overdrive.
jimmyo06
Post by jimmyo06 » Wed Sep 09, 2020 12:11 am
Thanks guys, I will book car in. To my garage and see , what arises
Post by philhoward » Wed Sep 09, 2020 4:32 am
And in reality, an EP 80W/90 will do both.
Post by nickkeyser » Wed Sep 09, 2020 8:11 am
Does the overdrive box have a filter in it?
SSSC Champion 2019
SS1 CVH 1600Ti
Post by philhoward » Wed Sep 09, 2020 8:41 am
Yes. Looks like there's 2 in a J-type: https://www.overdrive-repairs.co.uk/buy ... rts%20List
Post by scimjim » Wed Sep 09, 2020 8:58 am
correct - but as I said a modern multi grade is much better.
Post by scimjim » Wed Sep 09, 2020 9:00 am
one in the sump and a pressure filter under a screw cap - both metal so you can clean them, rarely any need to replace.
Post by nickkeyser » Wed Sep 09, 2020 9:16 am
Didn’t know that!
SSSC Champion 2019
SS1 CVH 1600Ti
Post by philhoward » Wed Sep 09, 2020 9:17 am
Didn’t know that!
Every day is a school day, Nick 8)
