Slow pulling Dick
speedy555
Diesel Dick is Exhausting
Post by speedy555 » Thu Oct 01, 2020 6:12 pm
Fat pipe up to the 1st silencer.
Which brings up another question....will 2x back boxes silence it enough, or is the original front box the best option?
Dave Speed
GTC #7 Diesel Dick se5a
Prev. Multiple SS1/ 68 coupe/ numerous 5s, 5a & 6a & 6b's / Cipher / rialto / Rochdale Olympic/ Gentry
5 series Registrar
www.ssgclassics.co.uk
Rochdales premier Scimitar Specialist :lol:
Paintwork and used spares :D
Post by philhoward » Thu Oct 01, 2020 6:13 pm
The turbo will silence it a fair chunk.
speedy555
Post by speedy555 » Thu Oct 01, 2020 6:32 pm
Today's gift from the positie
Dave Speed
5 series Registrar
Post by philhoward » Thu Oct 01, 2020 6:34 pm
I’ve got one of those for the 1.8 CVH 8)
Post by scimjim » Thu Oct 01, 2020 6:48 pm
I don’t have any silencers on diesel - 3” pipe straight from the turbo - sounds great :D
speedy555
Post by speedy555 » Thu Oct 01, 2020 6:51 pm
Might get away with just a back box then 🤔
Dave Speed
5 series Registrar
Post by philhoward » Thu Oct 01, 2020 6:55 pm
Ah - but you’ve got another couple of cylinders..
speedy555
Post by speedy555 » Thu Oct 01, 2020 7:07 pm
Mine sounds like an old Taxi 🤣💩
Dave Speed
5 series Registrar
speedy555
Diesel Dick cold start
Post by speedy555 » Sun Oct 04, 2020 8:44 am
My new ford book has confirmed that the wires from the injection pump I questioned earlier are as suggested, a cold start device.
My understanding of electrics is just below basic, and injection pumps below that.....so, my understanding from the book is that it is live from the ignition, and the earth is switched (via the extra temp sender) , and when up to temp the earth is switched on, which then turns the cold start solenoid off ?? 🤔❓
Left disconnected as it is now, starting etc isnt an issue, but will there be issues with it once warmed up? Over fuelling? Less performance?
Dave Speed
5 series Registrar
Post by philhoward » Sun Oct 04, 2020 8:54 am
Not sure about performance but one in permanent “cold start” mode both smokes more and sounds noisier..stands to reason that it’ll also lose some pit ponies as well?
speedy555
Diesel Dick cold start electrickery
Post by speedy555 » Sun Oct 04, 2020 9:05 am
But I'm correct in my thinking of how its wired and operates?
When I wired mine up it just smoked, so guessing faulty. I'm happy to replace it if worthwhile and my wiring is correct :D
Dave Speed
5 series Registrar
Post by philhoward » Sun Oct 04, 2020 9:11 am
I think you’re right - makes sense anyway.
speedy555
Post by speedy555 » Sun Oct 04, 2020 9:13 am
Thanks 👍
Dave Speed
5 series Registrar
Post by Old and Slow » Sun Oct 04, 2020 10:26 am
The circuit diagram shows the CAS (10) fed from the ignition switch and earthed via the contacts in the Energy Management Relay (12) so provided the EMR is powered up once the engine is warm then the CAS should drop out and retard the injection timing.
That's my take on it anyway. Diesel experts may be along shortly to tell you the value of my opinion !
speedy555
Post by speedy555 » Sun Oct 04, 2020 11:13 am
No engine management relay on Dick.
I thought earth was supplied via the temp sender.?
Or does the sender supply the earth but goes via the EMR first?
Dave Speed
5 series Registrar
