Smoking Dick
speedy555
Smoking Dick
Post by speedy555 » Sat Aug 01, 2020 10:20 am
I'm in the process of getting my latest 5a "Diesel Dick" roadworthy. It has a return pipe for Diesel to the tank which I either need to modify or replace.
Does it need to return to tank or can it just tee back into the fuel line in the engine bay before the filter?
Thanks.
Dave Speed
GTC #7 Diesel Dick se5a
Prev. Multiple SS1/ 68 coupe/ numerous 5s, 5a & 6a & 6b's / Cipher / rialto / Rochdale Olympic/ Gentry
5 series Registrar
www.ssgclassics.co.uk
www.facebook.com/ssgclassics
Fibreglass liquid coating technician - used spares
Diesel Dick
Post by philhoward » Sat Aug 01, 2020 10:42 am
I think diesels of that vintage need a clear run back to tank as it’s main run for the leak off pipes? They’re bad enough to bleed at the best of times so you don’t want to introduce (possibly) aerated fuel into the feed line.
scimmy_man
Diesel Dick
Post by scimmy_man » Sat Aug 01, 2020 11:10 am
what he said
or you need a swirl tank,
run the return pipe
speedy555
Diesel Dick
Post by speedy555 » Sat Aug 01, 2020 11:37 am
Ok thanks, I'll just renew the return pipe, but out of 2 or 3 pieces rather than the 6 or 7 currently, and of various materials 🤔
Dave Speed
5 series Registrar
speedy555
Diesel Dick
Post by speedy555 » Mon Aug 03, 2020 12:06 pm
Next question is, what is this cylindrical bit on the pump? It is connected to the fan sender switch, but is disconnected ATM with no apparent issue.
Fan isnt wired up yet but wondering if I need to wire this up for some reason.
Dave Speed
5 series Registrar
Diesel Dick
Post by philhoward » Mon Aug 03, 2020 12:14 pm
Shut off solenoid?
Diesel Dick
Post by philhoward » Mon Aug 03, 2020 12:17 pm
Probably not thinking about it; could it be a cold start "idle up"? Maybe (and yes you could get a Sierra TD with AC) it would add a few rpm when the AC was switched on?
speedy555
Diesel Dick
Post by speedy555 » Mon Aug 03, 2020 12:46 pm
Well whatever it is seems surplus to requirements 8)
Dave Speed
5 series Registrar
Symmo
Diesel Dick
Post by Symmo » Mon Aug 03, 2020 5:55 pm
Not sure what engine your using but the solenoid could either be a shut off valve or an excess fuel device for cold starting., as for the return pipe it does need to go back to the tank to prevent any aeration of the fuel and also ensure you use the correct size of return pipe. Had a ERF tractor unit brought in to us which had an engine swap from a Rolls Royce engine to a 14 ltr Cummins engine but just had a major lack of power, traced the problem to the fuel return pipe as they had used the Rolls Royce pipework wich was 1/2 the size of the Cummins fuel system.
speedy555
Diesel Dick
Post by speedy555 » Mon Aug 03, 2020 7:09 pm
Doesnt seem to be a relay, or at least I can't get a click from it if I wire it up. I seem to have 2x fan switches, a 2 pin on the stat housing and a 4 pin in the top hose, and these seem to have been all linked together with the mystery wiring on the pump.
Seems to start and run fine all unplugged though, and was just intending to use the 2 pin fan switch.
Dave Speed
5 series Registrar
Diesel Dick
Post by philhoward » Mon Aug 03, 2020 7:24 pm
Seems to tie in with previous aircon fitment?
speedy555
Diesel Dick
Post by speedy555 » Mon Aug 03, 2020 7:36 pm
Possibly as seems sierra fittment only. I have a manual on the engine, but doesnt cover the particularities of the sierra, and there's no mention of it in the book, so guessing sierra only spec.
Dave Speed
5 series Registrar
speedy555
Diesel Dick
Post by speedy555 » Mon Aug 03, 2020 7:40 pm
Next job is to find an alternative to the wonderfully engineered alternator bracket :lol:
Dave Speed
5 series Registrar
scimmy_man
Diesel Dick
Post by scimmy_man » Mon Aug 03, 2020 7:43 pm
take a look at a scimitar handbrake adjuster, (you may have one?) it will fit there nicely.
speedy555
Diesel Dick
Post by speedy555 » Mon Aug 03, 2020 7:46 pm
I was hoping to turn the alternator over and put the adjuster downwards to the block somewhere.
Dave Speed
5 series Registrar
