My Purple Project - SE5a 1973
Post by philhoward » Thu Sep 10, 2020 12:56 pm
I think those ones are usually filament?
GavinR
Post by GavinR » Thu Sep 10, 2020 2:32 pm
If you mean the VWP sticker sheet, they are a sensible size to stick onto SE5a rocker switches
Like this
Scimitar 160.jpg (73.95 KiB) Viewed 669 times
GavinR
RSSOC Member 3513
1971 SE5a
1970 SE5 Project
adamwilkes
Post by adamwilkes » Thu Sep 10, 2020 3:42 pm
It's this transparent sheet of symbols etc (in white or black): https://www.vehiclewiringproducts.co.uk ... mbol-sheet
vehiclewiringproducts symbols sheet.jpg (56.22 KiB) Viewed 652 times
Adam Wilkes
GavinR
Post by GavinR » Fri Sep 11, 2020 12:23 am
Yes, exactly the same as I used on the rocker switches about 9 years ago!
GavinR
RSSOC Member 3513
1971 SE5a
1970 SE5 Project
adamwilkes
Post by adamwilkes » Sat Sep 19, 2020 6:51 pm
Cat amongst the pigeons - when I returned home last night, both the 'lost for ten weeks' Chinese lights AND the replacements from vehiclewiringproducts were in the parcel box :shock: I do like the originally-chosen Chinese ones (posted from Singapore), so I shall try those I think! They are smaller (fit the holes I have drilled) and have the built-in warning symbols. New speedo seal from QRG is also here, so a busy time ahead :D
Oh, and I have ordered a cheap air-to-fuel-ratio meter/sensor plus weld-on boss to experiment with a 'sniffer' removable tail-pipe to see what the petrol mixture is doing on each bank of the V6 :D May be more informative than the slow-to-react CO mixture analyser I have.
wideband afr kit.jpg (73.99 KiB) Viewed 510 times
Adam Wilkes
adamwilkes
Post by adamwilkes » Mon Sep 21, 2020 6:43 pm
Speedo shaft seal at the auto gearbox has now been renewed (thanks QRG), and the internal diameter of the old one was obviously worn large so hopefully that's a leak fixed! Access is limited to tap the seal back in, so a small socket and the side of a hammer tappity-tap about a hundred times got there in the end.
Adam Wilkes
adamwilkes
Post by adamwilkes » Sun Sep 27, 2020 6:27 pm
I'm going for 'unimpressive photo of the week' award: My new improved dashboard warning lights are fitted :D I am very happy with them in fact - particularly that the 'P' warning light (perhaps unique on a SE5a Scimitar) works very well 8) Boy with a new toy.
Photo shows them all switched on, including the radiator fan warning via the manual over-ride switch. Left-to-right in the photo: low fuel; brakes (handbrake and/or fluid level); rear fog light; radiator fan; heated rear screen; park/neutral gear position. Not sure of the light LED colours, but there wasn't a choice except for the symbols. Spent two hours just wiring these six lights in ! Ridiculous; then spent another hour tidying the rat's nest and also repairing the intermittent handbrake warning switch. Was a nice sunny day, so it couldn't be wasted indoors :wink:
I next need to bleed the oil pressure pipe to the pressure gauge. I had what looked like low pressure some time ago, but later realised that there were air bubbles in the hose from being disconnected; just like brake pipes I suspect pressure doesn't fully reach the gauge when there is air in the pipe :shock: It's just a case of running the engine without the pipe connected to the back of the gauge until it runs bubble-free, then screwing it back on. I expect a mess; I am good at that.
new warning lights.JPG (93.04 KiB) Viewed 425 times
Adam Wilkes
Post by scimjim » Sun Sep 27, 2020 8:31 pm
Like the lights (although I can’t see the point in a Park light) - I’ve never needed to bleed an oil gauge pipe.
Post by Old and Slow » Sun Sep 27, 2020 9:01 pm
IMHO the air bubbles will compress to the same internal pressure as the oil that is compressing them, so ought not affect the gauge.
I hope I'm wrong, so good luck, get ready to catch lots of oil though!
adamwilkes
Post by adamwilkes » Sun Sep 27, 2020 10:28 pm
I reckon you are dead right; at the time of typing it felt wrong about the oil & air fooling the oil pressure gauge but I couldn't quite get why. The brakes analogy isn't right, as it's the squashiness of the air in the pipes that makes you run out of pedal-travel - once the brake pedal & pads are stationary, the pressure will be transferred to the other end of the pipe. Apologies for the misdirection :oops: Must remember my O-level Physics better :?
Adam Wilkes
Post by Old and Slow » Mon Sep 28, 2020 9:27 am
That begs the question - what do you think is wrong with your oil pressure gauge readings?
You know there are lots of willing helpers (metaphorically speaking) out here with years of experience... :)
adamwilkes
Post by adamwilkes » Mon Sep 28, 2020 11:01 am
Yes, the forum members are a treasure trove of knowledge; I shall change the oil filter to the well-respected ford one before I consider there being a problem with the gauge or engine.
Adam Wilkes
Post by philhoward » Mon Sep 28, 2020 11:42 am
Worst case with air bubbles is you get a bit of damping. If the pipe was black (like the original) you’d be none the wiser 8)
adamwilkes
Post by adamwilkes » Fri Oct 02, 2020 1:57 pm
Well, a momentous day :P I drove the car On The Road :shock: I first fitted the dashboard and indicators stalk - plus as a luxury - the steering wheel.
Even with my petrol priming bulb, it takes ages of churning to start it up, then subsequently it starts instantly; this is lucky because I think the mixture is far out and the engine stalls on some tickover-to-drive transitions. It went about half a mile, all in first gear (automatic 3-speed) or reverse, around a couple of mini-roundabouts and back onto the driveway. Exhausting :| The tyres feel a bit 'square' (original 30-yr-olds) and something scrubs/rubs on full RH lock. Otherwise, smelly, noisy and fun :D Rev-counter has given up & the indicators tell-tales are all but invisible and inaudible; wipers go from left-to-right and the rain stays where it is :lol: Some work still to do!
Adam Wilkes
Cutwaterdrummer
Post by Cutwaterdrummer » Fri Oct 02, 2020 2:02 pm
Congrats, Adam! You're going to enjoy it! Much admiration for you and all the others who have the skills and patience to undertake these daunting projects.
RBW - SE5a Nevada Yellow Peril
www.cutwaterband.co.uk
