RX8 gearbox into 5a
CarlosVanDango
RX8 gearbox into 5a
Post by CarlosVanDango » Sun May 03, 2020 6:56 pm
scimjim wrote:
Sun May 03, 2020 5:53 pm
Might have to look at the Mazda flywheel tonight.
they are more like an auto flexplate - i wanted to use one for mine they bolt to the rotary crank with 2 bolts and don't look like they have much mass to them
i had a look at some pictures and thought sod that :lol:
RX8 gearbox into 5a
Post by efi_sprintgte » Sun May 03, 2020 6:57 pm
scimjim wrote:
Sun May 03, 2020 6:55 pm
I went back to KISS principles and drilled a hole in it to take an SE5 engine mount but didn’t take a pic :D
That was going to be my plan :lol:
RX8 gearbox into 5a
Post by philhoward » Sun May 03, 2020 8:29 pm
I’ve got a gearbox mount consisting of an M10 bolt sandwiching some rubber doughnuts and washers. Seems to be doing the job.
Unlike the snazzy poly mounting washers that broke up into 10mm chunks as soon as any pressure was applied to it - like tightening the bolt..
CarlosVanDango
RX8 gearbox into 5a
Post by CarlosVanDango » Mon May 04, 2020 7:46 pm
but this is a better shot of mine sat in situ -the plywood packer is 1"
plan C now is to make a cradle picking up of the 2 larger lower studs that i have removed, i'm going to get some bolts that bolt the cradle into the threads and the cross member should just clear the heads
for the rubbers i'm looking at something simple like land rover ones
RX8 gearbox into 5a
Post by scimjim » Mon May 04, 2020 7:49 pm
Have you checked the output shaft angle versus axle angle? Just from measurements, I make it a bit less than 1” but that’s only theoretical. The SE5 engine mount I’ve mocked up is about 1” though.
RX8 gearbox into 5a
Post by efi_sprintgte » Mon May 04, 2020 8:00 pm
Could always space that crossmember down from the chassis a few mm.
CarlosVanDango
RX8 gearbox into 5a
Post by CarlosVanDango » Mon May 04, 2020 8:03 pm
i measured the height of my old output shaft of the scimitar box (mine was O/D not sure if that makes a difference?) i'm matching it to that
CarlosVanDango
RX8 gearbox into 5a
Post by CarlosVanDango » Mon May 04, 2020 8:04 pm
also could cut away a bit of the cross member where it would foul :idea:
CarlosVanDango
RX8 gearbox into 5a
Post by CarlosVanDango » Mon May 04, 2020 8:37 pm
this was the mount i was thinking of - it'll be tight but they should just squeeze in....... hopefully :lol:
its a L/H defender mount part no ANR3201
the l/h and the r/h are different sizes so i would just get 2x l/h ones
CarlosVanDango
RX8 gearbox into 5a
Post by CarlosVanDango » Mon May 04, 2020 8:47 pm
just been out and tried it - my scimitar is still on the wheels so it was tight to get a decent picture but it will fit
this will be how it fits and one opposing the other side
i've just ordered 2 new ones as this one is a used one and it's got slight wear in - good enough to save for a land rover but not up to scimitar standards :lol:
GavinR
RX8 gearbox into 5a
Post by GavinR » Mon May 04, 2020 11:38 pm
Or try a Capri cross member which is already lowered
It should be wide enough to reach the chassis rails - I can measure one if needed
e.g. https://www.ebay.co.uk/itm/Capri-Gearbo ... 2248420755
GavinR
RSSOC Member 3513
1971 SE5a
1970 SE5 Project
CarlosVanDango
RX8 gearbox into 5a
Post by CarlosVanDango » Sun May 10, 2020 10:26 am
i've got my design drawn up (in my head) for my mount - i've took the 2 studs out of bottom mount, chopped them down and welded an M16/24mm nut over them to convert them to bolts, i will swap them for bolts but at the moment i'm unsure of the thread size
i'm making a 'u' shaped bracket that cradles the box using the lower mount holes and rests on top of my land rover mounts - i'll also tie it in one side to the other higher up mount for a bit of added strength
i'll weld 2 mounting bosses to my original scimitar cross member so to dismantle i can just undo the 2 nuts from underneath and 4 scimitar cross member bolts
ive also been looking into the clutch - i plan to use the RX8 slave cylinder i've found out the thread is M10x1 so i'll get a pipe made up that goes from the scimitar master cylinder to it
i've also found that to do this you need a .700 master cylinder, not sure what mine is (i've read it should be .625 standard) but it looks old so i'll get a new one to be sure the output thread on the new one is 3/8 unf but i think the scimitar standard is 7/16 unf
RX8 gearbox into 5a
Post by scimjim » Sun May 10, 2020 4:36 pm
Just done some measuring and there’s no way it will fit an Essex with the standard flywheel and clutch. The bellhousing and input shaft are far too short.
RX8 gearbox into 5a
Post by efi_sprintgte » Sun May 10, 2020 4:56 pm
I came to the same conclusion
RX8 gearbox into 5a
Post by philhoward » Sun May 10, 2020 6:15 pm
So what’s the solution from the guy(s) peddling them on Facebook? Block them?
