New to me....SE5a RBW
Post by scimjim » Thu May 21, 2020 9:28 pm
I’ve never seen round or straight through centre boxes. Either way, I wasn’t knocking the car, the underside looks great.
Post by gtcse8 » Thu May 21, 2020 9:33 pm
:oops:
tony1966
Post by tony1966 » Thu May 21, 2020 9:56 pm
the exhaust boxes are offset at centre
the rear boxes are fitted the correct way up-not a great fan of how they look myself either tbh[kinda gt6 style] but i am sure cliff will get it spot on to his own taste
at first i kinda liked the exhaust tailpipes tbh.but i did go off the look-i like the straight pipes out better
Cutwaterdrummer
Post by Cutwaterdrummer » Fri May 22, 2020 12:14 am
Thanks, guys, for the discussion and pointing this out, as I certainly didn't know about these details. The car came with another set of round stainless rear boxes that I could fit to get the original horizontal pipes, but I kind of like the angled look....at least for now, but that may change!
RBW - SE5a Nevada Yellow Peril
www.cutwaterband.co.uk
tony1966
Post by tony1966 » Fri May 22, 2020 9:33 am
yes-at least you have the choice of pipes-the pic makes it look like the centre exhaust silencers are straight,when in fact they have an offset when viewed in the metal as it were-i have seen pics of at least one other scim with that type of backbox fitted too
Post by scimjim » Fri May 22, 2020 10:14 am
They may have a slight offset but not as much as OEM - look at the alignment to the chassis mount.
tony1966
Post by tony1966 » Fri May 22, 2020 10:27 am
its certainly not an o/e system its got tubular manifolds,a very old stainless set up
rebel alliance
Post by rebel alliance » Fri May 22, 2020 10:30 am
I have those back boxes if they were the correct way up would the pipes be straight ?
tony1966
Post by tony1966 » Fri May 22, 2020 10:39 am
no,if you turned them around they would point sharply downwards :D
rebel alliance
Post by rebel alliance » Fri May 22, 2020 11:05 am
Odd the angles there due to the boxes being angled up when fitted if they were straight i could see them pointing down
adamwilkes
Post by adamwilkes » Fri May 22, 2020 11:16 am
I feel that since the rear boxes already point upwards going back, the tailpipe angle would be near horizontal if the boxes were turned upside down.
Adam Wilkes
rebel alliance
Post by rebel alliance » Fri May 22, 2020 11:48 am
adamwilkes
Post by adamwilkes » Fri May 22, 2020 11:59 am
The spider makes it for me :P
Adam Wilkes
tony1966
Post by tony1966 » Fri May 22, 2020 12:05 pm
lol they are mounted horizontal and stick up say 30 deg or so..so turn that around maybes 30 deg downwards?
i didnt fit the tailpipes -the dealer i got it from had removed the straight pipes to fit them-i did however shove them in a couple of cm
loving the spider btw-i"d patent the little chap myself if i were you :mrgreen:
rebel alliance
Post by rebel alliance » Fri May 22, 2020 12:14 pm
Ahh makes sense now its the correct box but the rear pipe is missing the upward bend...wish you had said that before i got my colouring set out 😁
