SS1 1800 CVH Project update still misfire
SS1 1800 CVH Project More wiring queries
Post by scimjim » Thu Jun 11, 2020 5:42 pm
I think that brown should be going to earth - normally connected to the nearest rocker box cover bolt. I can look this weekend if no-one reports back sooner.
Post by philhoward » Thu Jun 11, 2020 6:07 pm
Centre pin on a 3 pin is earth:
scimjim, this is off 686 - shall I put it the box of bits to come to you?
Post by scimjim » Thu Jun 11, 2020 6:42 pm
Might as well, you’re not going to need it 😀
Post by philhoward » Thu Jun 11, 2020 6:46 pm
Very true..
Post by reliant-reviver » Thu Jun 11, 2020 8:04 pm
There are two different wiring sets dependent on distributor. The brown wire on the Lucas 3 pin plug would normally earth to the body of the distributor - never seen one to the rocker cover bolt, that's certainly not the original arrangement.
For the Bosch (3 lug, long body, blue cap) it's only a 2 wire plug and a separate adaptor harness is used which plugs in to the usual coil connectors and then replaces them. Can't recall the actual wiring, but it sounds to me like someone has effectively tried to do that by means of splicing.
Post by scimjim » Thu Jun 11, 2020 8:22 pm
I wasn’t suggesting it was original :D
But it would be black originally :D
Peter S
Post by Peter S » Fri Jun 12, 2020 7:06 pm
Thanks all I was thinking it was an earth
The other black lead soldered to the white coil wire must be for the electric choke
Progress today
I've insulated the bare wires and discovered that the temperature controlled vacuum valve? On the inlet manifold is broken :!:
Peter S
Post by philhoward » Fri Jun 12, 2020 7:20 pm
I wouldn’t be worried about that - ignore it and just go from dizzy straight to carb.
Post by Alan SS1 » Sat Jun 13, 2020 4:48 pm
OK down south, but gave me issues in winter in ABZ :wink:
Peter S
Post by Peter S » Sun Jun 14, 2020 11:38 am
I did wonder why there is a heated inlet manifold, I thought you were supposed to have cold air and fuel going into the cylinders :!: I have lived is Scotland though when the average maximum daily Temperature in February was -1c so I know it's a little different up there :D
Anyway another stupid question
Where does this bracket attach :?: And what goes in the other clamp clutch or speedo cable :?:
It's currently attached to main battery cable but I can't see where the other end (by the water hose ) goes
Peter S
Post by Alan SS1 » Sun Jun 14, 2020 7:15 pm
clutch cable on mine, but i routed the speedo-cable the wrong side of steering column :-(
looks like yours has also been rubbing . . . . .
couple of cable ties have fixed it :-)
Post by scimjim » Sun Jun 14, 2020 8:09 pm
The manifold isn’t heated?
Post by philhoward » Sun Jun 14, 2020 9:10 pm
Water heated, yes.
Peter S
Post by Peter S » Thu Jun 18, 2020 5:52 pm
I've found why the hazard switch was not working properly
So if your hazards only work with the switch pushed fully in and the ignition lights come on you know what it is :!:
I've managed to straighten the contacts and all OK now
In other news I've got sparks :D The engine turns over on the starter - with the plugs removed
All :!: I have to do now is refit the rebuilt carb, finish the fuel lines and fill the cooling system before trying to start the engine for the first time. It's never been started since it was built up over 10 years ago :!:
Peter S
Peter S
Post by Peter S » Sat Jun 20, 2020 6:29 pm
Well I've briefly got the engine running :D I filled the float chamber after turning it over without the plugs in untill the oil warning light extinguished and after a few reluctant turns it fired :!: A bit lumpy but just about cleared when it ran out of fuel
Bad news there's a leak from the water pump casting you can see the drip on the sump about 1 drip per second
Has anybody any thoughts on "K seal" or failing that I presume it's cross member out crank pulley off cam belt off to get at it. :?: I fairly sure it's "new" that is unused but 10 years old. I suspect it's just a gasket.
Peter S
