71 GTE SE5A my rolling restoration and now Tdi conversion
CarlosVanDango
Post by CarlosVanDango » Wed Apr 22, 2020 6:57 pm
few more pics
this is the finished plate (gearbox side)
engine side
i had an issue with one of the bellhousing bolts landing on top of the plate bolt so i made this clamp to get round it - should be fine - all the other bolts are ok and the 2 locating dowls fit perfect
CarlosVanDango
Post by CarlosVanDango » Fri Apr 24, 2020 8:39 pm
engine and box bolted together
1st rwd mazda box'd 1.9Tdi i've seen
close up of the plate (bolts will be swapped for correct length ones)
bit of a hassle getting it in
it's sat like that (well a bit further) going to continue tomorrow :D
Post by scimjim » Fri Apr 24, 2020 9:34 pm
Much easier with the front on axle stands :D
CarlosVanDango
Post by CarlosVanDango » Fri Apr 24, 2020 9:48 pm
yeah i think i'll have it up on stands tomorrow
this is how its sitting for tonight, need to get it back a few inches and dropped level
the Tdi is a tiny engine and it's tight as hell, i don't know how people manage to get 6cyl and V8 engines in there :lol:
i think i'm gonna have some problems shutting the bonnet - looks like i'll have to chop the inlet down or at least bin the EGR, but i'll see how it goes difficult to get an exact measurement now
hopefully that's all i need to do - looks close on the sump too :?
Post by efi_sprintgte » Fri Apr 24, 2020 9:52 pm
Sump close to what?
CarlosVanDango
Post by CarlosVanDango » Fri Apr 24, 2020 10:05 pm
Sump close to what?
to the chassis crossmember thats just behind the steering rack
Post by scimjim » Fri Apr 24, 2020 10:16 pm
Looks like it needs to go back so the sump clears? The crank pulley is only just over the crossmember as standard.
Post by scimjim » Fri Apr 24, 2020 10:18 pm
BTW is the picture rotated for everyone else?
Post by efi_sprintgte » Fri Apr 24, 2020 10:19 pm
Yeah 90 deg clockwise
CarlosVanDango
Post by CarlosVanDango » Fri Apr 24, 2020 10:21 pm
yeah back about 2-3" i think, ran out of time needed to clear all my tools up as i'm working in the street
i'll get some better pictures tomorrow when it's sat correct
i don't know why the picture is that way round just uploaded that way :? :D
Post by scimjim » Fri Apr 24, 2020 10:29 pm
Fixed the pic.
I think moving it back to clear the sump will solve your bonnet clearance issue too? My straight six has no bulkhead or heater!
Post by efi_sprintgte » Fri Apr 24, 2020 10:37 pm
Can’t be much longer then this 4pot?
https://scimitarweb.co.uk/sgwrs/viewtop ... 08#p482308
Post by philhoward » Sat Apr 25, 2020 5:28 am
I do recall having a giggle when I learned the only Jaguar XF with a “power bulge” in the bonnet was the 2.2 Diesel, being the only 4-pot. This is a car that goes up to a supercharged V8 too.
Get it further back and dropped down the back of the crossmember and that should help your height issue. Just keep an eye on the sump and how much sticks out the bottom.
To get the last inch of clearance to level things up, I had to trim the tunnel on my 5a; where the front ashtray sits there’s a “divot” in the fibreglass which pokes down into the tunnel and might stop the gearbox sitting where you think it should have. Just chop it out but the centre console fixing bracket sits in this divot so will need a little adjusting too. This was on the Scimega though - different gearbox where the gear-lever is actually mounted on the body (not direct to the box like the Mazda boxes) so gearbox position was quite critical.
Post by MikeyBikey » Sat Apr 25, 2020 7:36 am
Looking good,
Precision clutches made me a brand new plate for about £80. They’ll do them with whatever centre drive /diameter you want. And almost next day service.
The bulk head has several layers /skins. Don’t worry about cutting / trimming. I took out two skins for my Vauxhall transplant
CarlosVanDango
Post by CarlosVanDango » Sat Apr 25, 2020 10:04 am
yeah i know - reading threads like made me think ah it'll fit no problems :lol:
to be fair the pd is short but has a lot of crap on the back of it
