71 GTE SE5A my rolling restoration and now Tdi conversion
CarlosVanDango
Post by CarlosVanDango » Sun May 17, 2020 2:05 pm
Well i've got it in, bit of work and it's very tight :)
ignore the spare it was off a honda jazz just to trial it, was the closest thing to the size i want to fit
ideally i'd like to swap to 15" wheels with 205/50R15 on the front and 225/45R15 on the back so i could get a 175/65R14 spare that would be the same rolling radius, this one is 175/65R15 so about 1" bigger but at least if this fits the one i want will. my original spare was a 205/70R14 and wouldn't even fit with the essex in without letting the tyre down -so no chance now.
still not worked out where everything is going to go but if i can i'll fit a slimline fan between the rad and the engine - i've got about 60mm before the rack gets in the way
i think i'll put the air filter and intercooler in front of the rad - there isn't much space for a scooby style one and i don't know if it'd be as effective there
you can just see the rad through all that :lol:
and this is the alternator issue - still not sure if the smaller one will fit - i managed to get the top mount in on this one just to have it in place while deciding where to route all the water pipes. water pipes will have to go one over and one under the alt.
Post by philhoward » Sun May 17, 2020 6:07 pm
That’s cosy...
CarlosVanDango
Post by CarlosVanDango » Fri Jun 05, 2020 7:32 pm
earlier on in the thread i mentioned that the vw oil filter/cooler housing fouled the chassis leg, well this is my solution to it.
I've tried a few relocate ideas but in the end i've decided to use the original one I'm making a spacer place to pack it out from the block
i've made 2 plates and bolted one to each - hopefully the way i understand it there are 4 ports, main oil feed in (lower right) main oil feed out, smaller one to head (upper ones) and the lower left one is to drain to the sump for when the filter is removed
held the filter in position and tacked some sprags in - weldings not great i was holding this in place while trying to get a good angle with the mig but it doesn't matter these will be cut off they are only to get the angle right
removed the filter and now removed the adaptor - next step is to weld in the 4 joining pipes.
Post by MikeyBikey » Fri Jun 05, 2020 7:36 pm
That looks neat
CarlosVanDango
Post by CarlosVanDango » Sat Jun 06, 2020 1:44 pm
after all the messing about trying to find a smaller alt i decided to fit the original one and make a new bracket for it - luckily i have a spare bare block which i used to jig this up
still needs finishing off back lug mounts and some strength welding in but i can get the alt in the correct position and it fits with about 10mm gap to the upright now
i put the tensioner in the original position and in hindsight i should have made it higher up so now unfortunately i'll have to remove the tensioner when changing the alt but thats easy to do, on the plus side i can now easly convert the top bolt so i can remove that without the strut brace getting in the way
adamwilkes
Post by adamwilkes » Sat Jun 06, 2020 2:36 pm
That's quite some 3-D imagining you are carrying out there 8) Well done - can't wait to see how it drives :D
Adam Wilkes
CarlosVanDango
Post by CarlosVanDango » Sun Jun 07, 2020 7:47 pm
cheers
yeah me too - i drove a 130ps 1.9tdi polo the other day same which is a similar weight to the Scimitar and it went like stink - if the scim goes as well as that i'll be smiling :mrgreen:
other progress i'm making a full stainless exhaust from the turbo back 2.25" unfortunately it won't be twin exit pipes like the V6 had but not much i can do about that
i'm thinking of making it straight through with one back box and as its only small have no flex pipe so its all one piece- if its bad vibration wise i can add a flex pipe in.
start of it - welded with the mig as i've not got a tig
Post by scimjim » Sun Jun 07, 2020 7:54 pm
I’d try it without a silencer first? I was also going to split the pipe ahead of the axle and restore the twin pipe zen :D
CarlosVanDango
Post by CarlosVanDango » Sun Jun 07, 2020 8:19 pm
i started on dropping the fuel tank earlier and was looking at that - there is space for it to go through but i'm not sure the twin pipe is worth the hassle :lol:
what i might do is get it running with no silencer and see how it sounds - if its ok then run it all the way to the back like it
Post by philhoward » Sun Jun 07, 2020 8:53 pm
I though the unwritten rule was anyone with a single pipe exhaust must be 3”? Turbo is no silencer? Can’t remember what Drew fitted on his 5-pot 6a.
CarlosVanDango
Post by CarlosVanDango » Mon Jun 08, 2020 8:13 pm
i could jubilee clip a bean tin to the end of it Phil :lol:
finished the oil filter/cooler adaptor today and got it fitted in place
not the best pic but it clears everything - thats the main thing
CarlosVanDango
Post by CarlosVanDango » Tue Jun 09, 2020 7:29 pm
bit more...
finished the alt bracket
alt bracket.JPG (298.03 KiB) Viewed 936 times
and fitted
alt fitted.JPG (283.23 KiB) Viewed 936 times
looks like the t-piece for the oil pressure gauge will have to go elsewhere :lol:
Post by philhoward » Tue Jun 09, 2020 9:22 pm
Don’t you just these 3D jigsaws?
Especially ones like this which don’t have a picture on the box either :mrgreen:
CarlosVanDango
Post by CarlosVanDango » Mon Jun 15, 2020 9:49 pm
best type Phil :D
got a bit more done but don't seem to be any further forward :lol:
got the stainless exhaust tacked up this is as far as i'm going to do until it's running - i'll see what it sounds like and if i can live with it :D
old petrol tank off and new stainless one ready for an 8mm return line fitting in, i'm not sure which way to go with the supply pump i was thinking fit the golf in tank one in the tank but i'm not sure if it's the best way i also don't have a swirl pot in the tank
and i've had to cut a hole in the heater cover, going to have to fiberglass this up
and you can also see the fuel filter now mounted on a bracket off the engine
CarlosVanDango
Post by CarlosVanDango » Tue Jun 16, 2020 7:24 pm
measured up for the new fan belt, well alternator belt as that's all that's on it now i've deleted the PAS and air con
a 6PK883 fitted perfectly
also got the gearbox mount welded up
gearbox mount.JPG (442.91 KiB) Viewed 810 times
it's meant to be offset :D
