SST 1.4 & ti
SST 1.4 & ti
Post by scimjim » Fri Aug 21, 2020 7:51 pm
I think the nose panel is okay - I cut off the burnt wing. I’ll get photos this weekend.
I also have body tubs if you want to turn the blue one into an SS1 (and obviously lots of panels - all need paint)
SST 1.4 & ti
Post by scimjim » Sat Aug 22, 2020 5:01 pm
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Sat Aug 22, 2020 6:24 pm
Jim you have a PM.
Geraint
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Fri Oct 16, 2020 10:20 am
any ideas where these or similar can be bought?
the usual suspects don't have anything at the moment. I have bought some unseen that I thought would do but they are too large. I want them for the nose to bumper but they will have lots of other uses so some one must be making them.
thanks
Geraint
SST 1.4 & ti
Post by scimjim » Fri Oct 16, 2020 11:35 am
What size are they - M5/M6?
SST 1.4 & ti
Post by scimjim » Fri Oct 16, 2020 11:42 am
M6 here - these are aircraft spec, so quite expensive. The floating type are much better than the fixed type in most applications but cbs have these fixed type?
SST 1.4 & ti
Post by philhoward » Fri Oct 16, 2020 3:02 pm
I'd be tempted by these - although "only" M5.
EDIT: Their M6 studs are rather reasonable too (then go with nuts/wing nuts like the SS1 nose if actually possible?).
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Fri Oct 16, 2020 4:30 pm
cheers Guys I will look at those, I am surprised I can't locate similar ones to the originals they are so handy.
Geraint
SST 1.4 & ti
Post by gtcse8 » Fri Oct 16, 2020 4:53 pm
I started to make them, they are holding the door cards on VVV Geraint, M5 as I have stock of plated CS screws :wink:
But as I can`t access my machines just yet I can`t go into production.
I used "Clinch" nuts rather than induction welded types.
I still have a few "Nuts if you wanted a handful??, simply drill the correct size hole in your selected piece of steel and Peen the collar over.
SST 1.4 & ti
Post by CNHSS1 » Fri Oct 16, 2020 7:20 pm
AJL used to have the door card ones in stainless Geraint.
As for the larger ones, Demon tweeks, Merlin Motorsport and the like do 'floating captive nuts' in range of sizes
Screenshot_20201016-191925_Samsung Internet.jpg (53.01 KiB) Viewed 71 times
