G130 YCF sprint car
Dcrosby13
Been thanked: 136 times
G130 YCF my first sprint car
Post by Dcrosby13 » Sun Jul 28, 2019 4:23 pm
yeah we,ve moved to a T25/28 hybrid and a 3" exhaust from the turbo backwards
I break stuff...... :w
Dcrosby13
Post by Dcrosby13 » Sun Jul 28, 2019 4:31 pm
Dcrosby13
Has thanked: 178 times
Been thanked: 1230 times
Post by scimjim » Sun Jul 28, 2019 5:13 pm
Not a huge jump in turbo size then - is the wastegate closing fully?
Dcrosby13
Post by Dcrosby13 » Sun Jul 28, 2019 10:34 pm
It should be but I will check
Has thanked: 574 times
Been thanked: 500 times
Post by CNHSS1 » Mon Jul 29, 2019 9:38 am
Rule of thumb, when the WG penny is fully shut, the arm from the WG actuator should be half a hole out, ie need pulling 1/2 hole to fit the penny arm to give approx 3mm pre load. That will give original WG rated boost level. If you add more preload (if the actuator has a threaded arm) that will lift the boost threshold of ciurse
Dcrosby13
Post by Dcrosby13 » Mon Jul 29, 2019 11:26 am
Will take a look cheers guys.
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Aug 01, 2019 7:11 am
So I have conceded defeat and refitted the stock oil cooler setup, the remote oil filter and gubbins just kept leaking and I'd had enough, I managed to do it without lifting the engine but I don't want to do that again. At this point I did consider sticking more running in oil in but it's due on the rolling road this Saturday and the rings already seem well seated so I dropped and replaced it with Mobil 1 Motorsport oil. We haven't been happy with the brake pedal feel so whilst the car was on the axle stands a new even bigger master cylinder went on from an LDV van and some new polymatrix E pads went in as the existing ones were full on race pads and not very good from cold, the pads are bloody expensive but should hopefully be worth the effort. So we are all set for the rolling road Saturday morning, place your bets now! Stock injectors and ECU, T25/28 turbo auto sprint cam ported and polished head.
Has thanked: 370 times
Been thanked: 182 times
G130 YCF sprint car
Post by MikeyBikey » Thu Aug 01, 2019 8:25 am
:D :D
scimmy ben
Been thanked: 11 times
G130 YCF sprint car
Post by scimmy ben » Thu Aug 01, 2019 8:25 am
180bhp before you lean out...
G130 YCF sprint car
Post by CNHSS1 » Thu Aug 01, 2019 8:51 am
Adj fuel pressure regulator too? I'll go for 187hp
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Aug 01, 2019 9:09 am
Yup adjustable fuel regulator, last year we made 182 and the regulator was barely moved from base pressure
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Sat Aug 03, 2019 1:31 pm
209 BHP and 209 FT/LBS , it turns out that it was already running as much boost as the fueling could handle at 10psi because we tried 11 and it went lean. I saw 17 psi last week so im lucky I didnt break anything, it will be going back to Revlimit in September to have the standalone ECU, 444cc injectors and the forward facing CA20E inlet manifold fitted, the aim is 250bhp until the forged engine is ready then we have the option of pushing our luck with the gearbox :w
tony1966
G130 YCF sprint car
Post by tony1966 » Sat Aug 03, 2019 1:34 pm
thats a fairly smooth boost curve,should be decent for sprinting in such a lightweight car
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Sat Aug 03, 2019 1:34 pm
yeah it goes very nicely, already seen off a few "fast" cars
