SST H993WGF
scimmy ben
SST H993WGF
Post by scimmy ben » Wed Aug 29, 2018 4:25 am
CNHSS1 wrote:
Tue Aug 28, 2018 1:11 pm
're the rear mount dizzy, there's a blanking plate at the rear of the head iirc, but not sure the std cam has a dizzy drive?
I think you are right. I have a bluebird head that was ported and polished at Silvia Engineering and I have a Bluebird dizzy but it would end up with an ECU with a wasted spark/ coil on plug to make it work without the cam.
scimmy ben
SST H993WGF
Post by scimmy ben » Wed Aug 29, 2018 4:30 am
reliant-reviver wrote:
Tue Aug 28, 2018 11:45 am
Great minds think alike Ben. I refer to my earlier comments yet again -
Tue Jul 17, 2018 3:56 pm
Still. That bluebird turbo engine is begging for a big top mount turbo.
Would make a fantastic track car....
Anyone would think no one reads you posts that way you have to repost them :D :P
My inspiration came from having replaced melted distributor caps from a blowing exhaust manifold :roll:
scimmy ben
SST H993WGF
Post by scimmy ben » Wed Aug 29, 2018 4:46 am
Some good 'head' shots (no giggling at the back) here https://www.ebay.com.au/itm/NISSAN-CA20 ... Sw~FJZMKLm
demonbluedays
SST H993WGF
Post by demonbluedays » Wed Aug 29, 2018 6:39 am
Looks like good head work for the price :roll: :mrgreen:
Tom "DemonBlueDays" Williams
1976 SE6 #141 "Mighty"
2009 Fox "King"
Former Owner Of
SST H993WGF
Post by Corky » Wed Aug 29, 2018 11:21 am
Every day is a school day :D
I've not really paid any attention to the Bluebird versions of the CA18ET engine before. I wonder if the owner of this car took inspiration from the GW racer?
I would imagine that the bottom ends are the same across the range, just the head and ancillaries up top are different?
It would be interesting to know what the differences were between all of the cams and dizzys and find out which bits are interchangeable. Around 8 degrees difference in lobe juxtaposition IIRC between SS and TS is now known :oops:
SST H993WGF
Post by philhoward » Wed Aug 29, 2018 12:06 pm
R-R suggested that the sump is different, so possibly the oil pickup as well?
Dizzy at the end is a double edged sword - keeps it away from the heat of the turbo but makes it as tricky as a CVH to get to!
SST H993WGF
Post by reliant-reviver » Wed Aug 29, 2018 12:34 pm
If you have seen the size of a TS dizzy, you would probably agree that it unlikely to fit back there. As to why this SST has a Bluebird engine, I suspect it is merely what was available.
Still regret not raiding more from the one that was in the local scrapyard a few years back.
SST H993WGF
Post by CNHSS1 » Wed Aug 29, 2018 1:00 pm
Checking part nos against the line drawings in the respective bluebird fwd and Silvia rwd manuals would prove differences
SST H993WGF
Post by scimjim » Wed Aug 29, 2018 4:51 pm
This is what’s behind the blanking plate on the back of my spare (originally in a RWD Nissan) engine. Snotty has the same.
SST H993WGF
Post by Corky » Wed Aug 29, 2018 5:24 pm
Same as mine. It looks too well engineered to be just there as a blanking plate though.
SST H993WGF
Post by CNHSS1 » Wed Aug 29, 2018 7:36 pm
If you look at Ben's post you can see the fwd casting is different
SST H993WGF
Post by gtcse8 » Fri Sep 21, 2018 9:10 am
Is it an optical dillusion, or is it an eccentric cam?
Could have been used for a manual fool pump possibly?
SST H993WGF
Post by philhoward » Fri Sep 21, 2018 9:13 am
I think it might be an optical dillusion?
No manual fuel pump on the injection head and the eccentric for the pump pushrod is somewhere around No.4 cylinder, not on the end.
SST H993WGF
Post by gtcse8 » Fri Sep 21, 2018 11:08 am
Bit of an update on this car.
Now has a set of decent seats.
Underbody Shutz applied to all metalwork.
Pair of new headlamps fitted.
Carpets all cleaned up.
New fool pump.
Brakes and cables all freed off.
Copper fool lines front to back.
Fool tank out and cleaned up inside and painted outside, before replaced.
MOT looking close.
I will try uploading a video onto youtube if I can work out how to connect the different footage into One continuous video.
The guys who have done all the work have now gone and bought Another project, so this car could be up for offers?.
SST H993WGF
Post by reliant-reviver » Sun Jul 05, 2020 3:31 pm
Just been posted on Facebook marketplace as breaking for spares. Body already cut up.
What a senseless waste.
Guess the other 20 or so SST 1800ti left just got that bit rarer!
