Ben's SS1 - Ti Sprint Car
Benc
Post by Benc » Sun Sep 20, 2020 1:57 pm
Hi Steve
Not new.
Its had a refurb at Turbo rebuilds. Very good price and service.
Post by Corky » Sun Sep 20, 2020 4:13 pm
Is it a T28?
Benc
Post by Benc » Sun Sep 20, 2020 4:57 pm
Yep
Benc
Post by Benc » Mon Sep 21, 2020 4:51 pm
MOT PASS today no advisories :D
So the plan is to run it until end of month then sorn.
Pull out the ET. In with the DET, sort all the wires, relays, pipes, exhaust, brakes, wheels, wheel arches...... :help:
Post by CNHSS1 » Mon Sep 21, 2020 7:11 pm
Good work Ben 8)
Post by MikeyBikey » Mon Sep 21, 2020 11:25 pm
Buy another car..... :w :w
Benc
Post by Benc » Wed Sep 23, 2020 10:27 pm
Mikey....tit
Post by Corky » Wed Sep 23, 2020 10:30 pm
Not sure that they’re the correct tools for the job Ben...
:mrgreen:
Or are they for the GTE ? :lol:
Post by philhoward » Wed Sep 23, 2020 10:33 pm
:mrgreen:
Only if it goes wrong.
Or you’re Mikey collecting the remains of another gearbox :lol:
Benc
Post by Benc » Wed Sep 23, 2020 10:34 pm
Multifunctional garage.....
Post by MikeyBikey » Thu Sep 24, 2020 3:38 am
:mrgreen:
:lol: :lol:
Benc
Post by Benc » Sat Oct 03, 2020 6:01 pm
Wiring a DET......
Decided to plug all the wires in
However the maf connector is a 3 pin which info suggests is for a catalyzer model....
Unfortanitly I only have 2 off 4 pin mafs
Also the power transistor wiring doesn't exist in the loom
The power transistor wiring from eccs does go to a brown and grey plug .....
Think there's going to be some head scratching to come
Post by Corky » Sat Oct 03, 2020 7:06 pm
Ben, I’ve got loads of bits of loom here including a full uncut one. I’ll be stripping off the biding tape, so hopefully you’ll be able to copy that.
AFAIK, having a three pin MAF won’t make any difference to you. I’d suggest that you socket the ECU and put a Horesham stage 2 chip in it. That should easily give you 250bhp with what you have already. I understand that that chip will disregard some of the values required by the stock chip, so not having a CAT or Lambda won’t be an issue (I had neither on my last DET).
Post by Corky » Sat Oct 03, 2020 7:09 pm
Sorry misread your post. You have a 4 pin MAF but a three pin plug. I think I may have the connectors and wiring to sort that out for you.
