Ben's SS1 - Ti Sprint Car
Post by BigBobPilot » Wed Jul 08, 2020 10:49 pm
For parts I've used Conceptua, there's no website, but they have an ebay shop & you can phone them.
Also JDM garage UK:
https://www.jdmgarageuk.com/
SS1 CA18DET race car
Benc
Post by Benc » Sun Jul 12, 2020 6:56 pm
A bit of det dismantling this afternoon.
Benc
Post by Benc » Tue Jul 14, 2020 9:03 pm
Just measured the bores of the metric DET in inches :D
The limit in the bore at grade 5 apparently is 3.2697inches I measured around 3.295inches.
That means a re bore and the forged bits are going in 8)
Post by philhoward » Tue Jul 14, 2020 9:18 pm
8)
I’ve noticed this thoroughly modern Japanese kit still likes the inches thing - the mounting bolts of my gear change remote were on 101.6mm centres.
Benc
Post by Benc » Tue Jul 14, 2020 10:13 pm
8)
More to do with the only internal mic I could borrow was a 2 to 12 inch oh er mrs
Post by philhoward » Wed Jul 15, 2020 5:01 am
So many choices, so little time :mrgreen:
If it’s within spec, it’s within spec, doesn’t matter if you measure it in mm, inches or picofurlongs.
Benc
Post by Benc » Tue Jul 21, 2020 8:41 pm
More inspection looking ok so far
Post by philhoward » Tue Jul 21, 2020 8:46 pm
Great news 8)
Post by CNHSS1 » Tue Jul 21, 2020 8:58 pm
You wanna get that G clamp looked at Ben, cant see it being much use... :lol:
Post by Corky » Tue Jul 21, 2020 9:31 pm
Good stuff Ben. I’ve been doing the same myself today, but without writing it all down :lol:
I had a go with the valve tool, and it worked a treat. Still a PITA to get the collets back in, but it worked.
Benc
Post by Benc » Tue Jul 21, 2020 9:54 pm
Yeh that model wont clamp anything between 0.0 and 24.99mm dia.... really annoying :shock:
Benc
Post by Benc » Tue Jul 21, 2020 10:01 pm
Do you have a good method of removing and fitting new valve seals?
Post by Corky » Tue Jul 21, 2020 10:04 pm
Long nose pliers to pull them off the valve guides. Then gently drop the new ones on (using the pliers) and push them home with your fingers or thumb.
Dcrosby13
Post by Dcrosby13 » Wed Jul 22, 2020 8:01 am
We have a proper valve stem seal tool if either of you want to borrow it
I break stuff...... :w
Benc
Post by Benc » Sun Jul 26, 2020 6:34 pm
Engine Block and head now stripped so ready for boring etc for the 84mm forged bits :D
