Will's GTC disasters
Post by scimjim » Tue Oct 30, 2018 7:50 am
and longer input shaft :)
Post by gtcse8 » Tue Oct 30, 2018 8:17 am
They cerpaintly did, one of my 6b`s is 4sp OD. :!:
Which incidentally is going to have to go, along with most of my other projects. ( The car that is, not the gearbox :lol: )
I`m resigned to the fact I will/can`t ever finish them for the near future. :cry:
I suppose I had better put this in the correct category :wink:
Will Yarrow
Post by Will Yarrow » Wed Oct 31, 2018 10:33 pm
Sorry to hear that Mark, I'm worried I'll never finish this one. I do have a couple of bikes to sell as well for the same reason, plus the new congestion charge rubbish.
Will Yarrow
Post by Will Yarrow » Sat Apr 20, 2019 7:58 pm
Well at last some progress has been made, an injector test bed was made and it failed due to the cheap chinese injector tester I got off amazon or ebay, it would fire one injector but not all six as planned, so all I could do was time how long it took 50ccs of fuel to pump through each one, not the acurate test I'd planned, but they all were with in half a second ish.
With the injectors roughly tested (VFR) I moved on to the clutch pilot bearing, it seemed silly not to change it whilst everythings apart. Looking on youtube, it was suggested packing behind the bearing with grease and a swift tap with a half inch bolt and a lump hammer, the bearing would move outwards. After I had wiped all the grease of my face i realised this wouldn't work. Back to youtube and bread was sugested in the same way, well why not and it really worked a treat, just ram it in there, hit and bob's your uncle.
Bread_is the _Answer_001.jpg (241.32 KiB) Viewed 2082 times
Bread_is the _Answer_002.jpg (228.56 KiB) Viewed 2082 times
Bread_is the _Answer_003.jpg (271.49 KiB) Viewed 2082 times
yes I know I could have made a puller, but the red mist had set in.
Once the weather had improved I got a few mates round to start putting the big bits back together. The chassis was in the back garden and upside down apparently.
and the engine in the garage
so a fair amount of lifting and cursing was required. luckily I knew the right people for the job and I promised beer.
worrying _moments02.JPG (251.33 KiB) Viewed 2082 times
And at last with Les on the engine hoist holding the back end and four of us lifting the front, it all went back together.
now the real work begins, thanks for listening.
Will Yarrow
Post by Will Yarrow » Sat Apr 20, 2019 8:03 pm
I have no idea why some photos have randomly rotated, they are all good my end, please feel free to rotate your laptops.
Post by philhoward » Sat Apr 20, 2019 10:13 pm
Like you, I have a 100% failure rate using grease to remove the bearing but bread is a new one on me!
Last time I needed to remove one I think I used a rawlbolt.
Will Yarrow
Post by Will Yarrow » Sat Apr 20, 2019 11:00 pm
The bread realy worked, just keep ramming more in, till it moves. Grease was useless as was silicone, I was going to use a chopped 10mm bolt, wedge and a slide hammer if that had failed.
David Tew
Post by David Tew » Sun Apr 21, 2019 12:50 pm
For about £20 you can get a set of blind bearing pullers to screw onto the end of a slide hammer.
Invaluable even if you have access to both sides of a bearing as they give a straight pull (and you don't have to raid the bread bin!). :)
Will Yarrow
Post by Will Yarrow » Sun Apr 21, 2019 8:45 pm
I was on a mission with the bread, but yes blind bearing pullers are definitely the better solution, bread is the best of the others though
Will Yarrow
Post by Will Yarrow » Sat Apr 27, 2019 8:19 pm
As I seem to have got a bit of momentum going now, I thought I'd start on the Gearstick and linkage, I rebuilt the manual gearshift I got from QRG over the winter, so it was just a case of fitting it, or so I thought. The hole in the prop tunnel had two holes that matched the front two holes in the Gearstick housing so I bolted it up and tested it, bugger it was an inch short.
Existing holes possition.jpg (307.15 KiB) Viewed 1853 times
So I had to reglass over the existing hole and cut a new one out, my first propper go at fiberglass.
Ground down.jpg (286.87 KiB) Viewed 1853 times
Taped up from below.jpg (120.73 KiB) Viewed 1853 times
Taped up from top.jpg (282.16 KiB) Viewed 1853 times
Cutup Matting.jpg (269.53 KiB) Viewed 1853 times
Glassed up.jpg (285.75 KiB) Viewed 1853 times
Chopped cup.jpg (314.01 KiB) Viewed 1853 times
Gearlever in.jpg (306.36 KiB) Viewed 1853 times
And I have gears.jpg (281 KiB) Viewed 1853 times
After testing all the gears worked, wahey! but what a horrible job it is fitting the linkages and tightening the housing under the car, never again.
Now I need a Manual pedalbox, if anyone listening has one in the shed there's an add on the wanted section, or just PM me. I did have this one but the bolt holes don't line up and the throttle pull is from the bottom, anyone know what it's off?
Post by DARK STAR » Sat Apr 27, 2019 9:27 pm
Pretty sure I have a SE6 one, presumably the same ... except I don't know if it's hydraulic or cable clutch.
I'll have a rummage tomorrow.
Post by philhoward » Sat Apr 27, 2019 9:46 pm
An SE6 one will be hydraulic- unless it’s a Middlebridge one in which case it’ll be cable.
That looks like a 5/a one to me?
Post by DARK STAR » Sat Apr 27, 2019 9:56 pm
I seem to think I got it for my brake conversion on the Coupé - which has a cable clutch (Middlebridge).
Were all SE6/a/b hydraulic ?
I didn't use it because it was too big, so it's in the garage ... somewhere 8)
Will Yarrow
Post by Will Yarrow » Sun Apr 28, 2019 12:51 am
Ah Darkstar, you sound like you have a garage like mine. It has to be for a hydraulic (excuse the poor spelling previously, I blame it on the fiberglass fumes) clutch, as thats the way it is now and it would be too much work to change it over.
Phil thanks for spotting what the other one was, another thing to sell when it's running unless anyone needs one now.
Will Yarrow
Post by Will Yarrow » Thu May 09, 2019 5:53 pm
Does anyone have a picture of a Middlebridge throttle pedal, i.e. the part where it conects to the throttle cable. I know what I can weld on to do the job, but wondered wether I had the right cable or if there's a more elegant solution. Also what's the switch/sensor on the engine end of the cable?
