SE5a YTY V8 project
rockhouse
SE5a YTY V8 project
Post by rockhouse » Mon Oct 21, 2019 12:40 pm
hi out of interest what size tilton did you use :D
Tinker man
SE5a YTY V8 project
Post by Tinker man » Mon Oct 21, 2019 1:17 pm
Hi, thanks chaps.
the tilton i bought is 7/8. hopefully it will be ok. some way off finding that out at the minute.
spoke too soon on no issues. the carb is flooding badly. so off at the minute checking float valve and heights as it is a second hand unit. fingers crossed its an easy fix. pressure is fine at just under 4 psi. edelbrock says it should be ok up to 6psi without a return.
i dont know what i have done wrong with the video link. can i upload from Google photos?
i will find a way. its still a good result for me i think. 8)
many thanks, Ian.
SE5a YTY V8 project
Post by philhoward » Mon Oct 21, 2019 1:30 pm
There's currently no video upload function for the forum - best I can suggest is uploading it to YouTube and post the link here.
Tinker man
SE5a YTY V8 project
Post by Tinker man » Mon Oct 21, 2019 3:29 pm
thanks for that Phil. i may have a go!
the good news is that i have fixed the carb issue (stuck float valve and incorrect float heights). so car running again now. :hurrah:
couple of exhaust blows on the homemade manifolds to sort out then back to the body for hopefully the last fiberglass repairs..
its moving along.
cheers
Tinker man
SE5a YTY V8 project
Post by Tinker man » Thu Oct 24, 2019 12:11 pm
hi gents,
try this link for the video. ignore the flappy fan belt. tensioner not yet on! fingers crossed it works. thanks, Ian.
Pepe
SE5a YTY V8 project
Post by Pepe » Sat Oct 26, 2019 9:45 am
Tinker man wrote:
Fri Oct 11, 2019 8:26 am
as part of my random approach i have also faced the wheel spacers and tack welded to make as one..... to make life easier when changing/removing wheels etc plus te spacers were rough and not particularly flat.
Had the same spacers in the front and can only say together with alignment via wheel nuts they sucked totally.
Had them replaced for proper turned parts (the ones on the picture are pressure cast.) that eliminated completely the shakey front axle I had..
1975 SE5a restoration link
Image Image
SE5a YTY V8 project
Post by Roger Pennington » Sat Oct 26, 2019 7:46 pm
Link works and car sounds good! :D
Tinker man
SE5a YTY V8 project
Post by Tinker man » Fri Sep 18, 2020 11:21 am
Morning,
more for my build file than anything else. the slowest project around is moving again.
after a few deviations, on other things (trailer rebuild completion, home building, 6a and even a driftwood horse :shock: ) there is a bit of time to devote to the V8 project. purists look away now.
body has been rubbed down to gel, Lechler coats applied as per the paint experts advice on here to the upper body. Jotun underneath and inside.
rubbed down and more applied. still work to do as can be seen but first guide coat on. more sanding and stoppering to follow. then another coat or two before applying a 2k top coat. not going to be a professional job, but should be more than acceptable i hope... we will see. AJL and Speedy need not worry themselves.
every small step gets me closer to getting the body and chassis back together. couldn't resist fitting one of the side vents.. just to see... you know how it is
lets hope i post again before the year is out!
cheers, Ian.
respray prep 1.jpg (72.01 KiB) Viewed 434 times
respray prep 2.jpg (77.41 KiB) Viewed 434 times
respray prep 4.jpg (109.52 KiB) Viewed 434 times
respray prep 5.jpg (92.49 KiB) Viewed 434 times
respray prep 6.jpg (73.67 KiB) Viewed 434 times
SE5a YTY V8 project
Post by philhoward » Fri Sep 18, 2020 11:26 am
Projects never really stop - the time between updates tends to grow though!
Tinker man
SE5a YTY V8 project
Post by Tinker man » Fri Sep 18, 2020 11:51 am
Very good Phil.. you should be a motivational speaker!
gasjunky
SE5a YTY V8 project
Post by gasjunky » Fri Sep 18, 2020 2:16 pm
In a previous life in Composites and Grp the Company Painter/sprayer used a product Lasonol (I think thats how it's spelt) to prime the grp items it was polyester based and would spray thru a gun then flat down like primer and Jotun resin I always used their resins and gel coats and epoxy based paints for quality and costs. it is a Norwegian company
Tinker man
SE5a YTY V8 project
Post by Tinker man » Mon Oct 19, 2020 10:27 am
Morning,
just for my own benefit on marking progress. main body now in primer. just needs final little niggles and last sand. quite a few layers on now. next job is some engine bay glassing (maybe a little out of order, but had the opportunity to get the paint on).
Paint primer 1.jpg (77.21 KiB) Viewed 165 times
paint primer 2.jpg (72.15 KiB) Viewed 165 times
just for a bit of fun also picture of the driftwood horse project mentioned above as an excuse for slow project progress.
wooden horse.jpg (204.91 KiB) Viewed 165 times
cheers for now, Ian.
adamwilkes
SE5a YTY V8 project
Post by adamwilkes » Mon Oct 19, 2020 8:49 pm
Nice horse - does need a little bodywork though :lol:
Adam Wilkes
manny
SE5a YTY V8 project
Post by manny » Mon Oct 19, 2020 9:14 pm
..at least the reins won't affect it... :drum:
Diyhell
SE5a YTY V8 project
Post by Diyhell » Mon Oct 19, 2020 10:50 pm
That horse is genuinely amazing!
SE6a needing lots of work...
