A New Project. The Pale Green 'Womble' SS1
Post by philhoward » Thu Oct 08, 2020 8:59 pm
Manifold to head, yes.
Manifold to downpipe, yes.
Post by scimjim » Thu Oct 08, 2020 9:15 pm
Manifold
Downpipe
Saber One
Post by Saber One » Fri Oct 16, 2020 11:53 am
What's the best way of sorting door, around the hinge holes and door skin , which matting/chopped strands to use ?? which resins (do they come with accelerator , hardener !!) Is it worth fitting a spreader plate in when repairing. have been on East Coast supplies website , but there's so much choice 😬. Will be my first attempt so simple answers appreciated 🙂 thanks
derekoss
Post by derekoss » Fri Oct 16, 2020 12:35 pm
Hi, I gave up using polyester resin and chopped strand mat a while ago. I use Wests epoxy and woven tape.
Found it much easier and stronger. Longer working time (with the slow hardener) if mixed in small batches. Mixing must accurate.
You pays your money............
Derek
Post by reliant-reviver » Fri Oct 16, 2020 12:57 pm
Post by Alan SS1 » Sun Oct 18, 2020 4:59 pm
remove all the rusty debris, if not already fallen off, remove the blown chopped strand, replace with any type of resin you fancy. I have used old style 'isopon /Davids for years on fixing the Regal/Robin etc. found some super high strength stuff from a local GRP tank maker, but by goodness it was HARD as anils when cured!!! (and used a special MEK hardner, I think dispensed in a minature whisky bottle . .. . .)
replace with a section of AT LEAST 16SWG steel plate on inner at top and outer at bottom, unless concerned about looks, but as you have an SS1, then low on priority? :wink:
adamwilkes
Post by adamwilkes » Sun Oct 18, 2020 9:29 pm
Rub down any surface to be repaired with, say, 40 or 80-grit paper or an angle-grinder sanding disc to give a really good key for the resin/mat - remove all paint/filler. Grab 1Kg of "450g (1.5 oz) Chopped Strand Matting - 1mt wide"; 5Kg "General Purpose 2-8500 Polyester Resin (including catalyst)" - the resin is more than you need right now, but costs hardly more than 2.5Kg of it. Look at: https://www.ecfibreglasssupplies.co.uk/ ... %2Facetone to see what I think you need, I've added some thinners (for cleaning) and a roller for getting air out of the mat - about £32. It won't hurt to add more mat if you think you may have more to do elsewhere. A couple of layers of this mat will make about 3mm grp thickness - not sure how thick you will need it, be guided by what was there and add more! You'll be ok vigorously using a paintbrush and roller to wet through the mat with resin. 2% catalyst approx - a little more if cold outside.
Adam Wilkes
