Sabre Turbo racer: 'Light Sabre'
Post by CNHSS1 » Sat Jul 04, 2020 1:10 pm
Will need a brace to either head or manifold itslef but also have to fabricate a stoplock for the existing internal wastegate penny so sandwich and brew and a think... :)
Post by nickkeyser » Sat Jul 04, 2020 1:42 pm
Looks good, well positioned too - you frequently see them tagged on at 90degree to the flow :roll:
You just locking the internal WG closed?
What make external is that?
SSSC Champion 2019
SS1 CVH 1600Ti
Post by CNHSS1 » Sat Jul 04, 2020 2:09 pm
Yeah angle relative to collector does make a difference. Also good to keep away from collector and main heat source, improves reliability of WG.
Its one from Batty, was ebay special copy of a Tial design feom nearly 15 years ago. Worked fine
Post by philhoward » Sat Jul 04, 2020 2:32 pm
I like these wonderful things called hole saws :mrgreen:
td99
Post by td99 » Sat Jul 04, 2020 3:55 pm
Drill, hole saw? You have a plasma cutter!
Post by CNHSS1 » Sat Jul 04, 2020 4:21 pm
Drilled a few holes, mainly to check i wasnt cutting through collector centre, then die grinder :wink:
Did think of plasma but thought a little overkill for a 5 min job
Post by CNHSS1 » Sat Jul 04, 2020 4:22 pm
'Very near' pulley on inlet side, need the alloy adpator black machining to fit the other to exh side so havent bothered as yet
Post by CNHSS1 » Sat Jul 04, 2020 4:23 pm
New cam belt fitted too
Post by b.c.flat hat » Sat Jul 04, 2020 4:52 pm
Is that thingy on top gona bust through yer bonnet? I 'ope not.
td99
Post by td99 » Sat Jul 04, 2020 4:59 pm
I wondered about that too, maybe power bulge coming up?
Post by CNHSS1 » Sat Jul 04, 2020 5:29 pm
Yeah it may need a clearance bulge
Post by BigBobPilot » Sat Jul 04, 2020 8:17 pm
You seem to have fitted an SU carb to your exhaust. Interesting!
SS1 CA18DET race car
Post by CNHSS1 » Mon Jul 06, 2020 8:26 pm
Ok so after comments yesterday ref WG, ive chopped it orf and reduced height about as far as i can go
Its now about 20-25mm above the rocker breather hose, so should just clear
Post by CNHSS1 » Mon Jul 06, 2020 8:28 pm
Removed and cut down bits off rear of plenum plate
Then fitted the Magnetti Marelli adjustable fuel pressure regulator (ex Cosworth)
Post by reliant-reviver » Tue Jul 07, 2020 11:57 am
Great to see it coming along, hope you can get the bonnet closed now, afterthought bonnet bulges aren't cool if you ask me.
So then, where's the screamer exiting, similar to batty? Scorch door marks because race car?
