Post by Corky » Tue Oct 06, 2020 6:18 pm
Yeh, love the coupe. I did fancy the Z3M, but they’re silly money now. At least it won’t dissolve if left outside, unlike an S2000 :lol:
Post by Oaksey » Tue Oct 06, 2020 6:36 pm
Don't speak too soon. I was looking at the Z4 Coupes but nearly all of them were bubbling at every seam. I gave up and bought the S2000 :lol:
1973 Beige Se5a Overdrive
1969 Se5
1972 Se5a
2005 Honda S2000
2016 BMW 330d
Post by Corky » Tue Oct 06, 2020 7:05 pm
Noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo :cry:
:lol:
Post by CNHSS1 » Tue Oct 06, 2020 8:36 pm
Z3M was a weapon! A proper M car 8) styling nit to everyones taste, but probably become a sought after and expensive classic (well on the way now)
There are plenty of S2000 coupe hardtops, suits the car well imho.
Benc
Post by Benc » Tue Oct 06, 2020 9:27 pm
About time you owned a decent car :w
Post by Corky » Wed Oct 07, 2020 10:01 am
:lol: Had BMW E30 and E36 back in the day and absolutely loved 'em, not had modern one though. I got put off when they started to fit run flats (early naughties IIRC), but I think all the handling issues associated with them are now properly sorted.
Post by Corky » Wed Oct 07, 2020 11:02 am
The postman has brought some more goodies this morning.
A Genuine Nissan dropping resistor (imported from Japan). Much cheaper to buy new than a 2nd hand one from eBay (eBay price circa £90, new price £47)
A pair of cam end seals
Fuel rail adaptor for pressure regulator delete.
Post by philhoward » Wed Oct 07, 2020 11:06 am
Surprising sometimes..always pays to check.
Post by Corky » Thu Oct 08, 2020 3:36 pm
I completely stripped the inlet manifold to its component parts today, and reassembled with new gaskets and seals. I've put the old manky hoses back in place, just so I can remember where they all go, and at a later date can work out which can be deleted from the build and which need to be replaced with nice shiny silicone stuff. There are hoses for fuel, water, vacuum and breathing, and I don't want to cock it up :lol:
Next jobs :-
Make it look pretty, by painting the various covers
Go through the wiring loom, delete the bits that aren't needed and wire in relays for Fuel Pump, ECCS and Ignition. Add the knock sensor wiring into the main loom.
Sort out exhaust side and turbo
Post by Corky » Sat Oct 10, 2020 4:33 pm
Just spent some time working out which bit of loom goes where and mapping it to the pin outs that Ben G sent me. I think I’ve got my head around it now and it looks like I’ve got everything I need to make it run.
A bit of a false start on the ECU front, as mine is a 39F code which is 3 pin MAF and Lambda. You need a 44F code to run the 4 pin MAF. I found one on FB for £30 that was already socketed, so add in a Horesham chip and it’s good to go.
Post by Corky » Sat Oct 24, 2020 12:57 pm
Not had a chance to get in the garage now for two weeks, I've been busy fitting a new bathroom, which has turned into an epic as I decided to fit a new ceiling and then decided that the floor boards wouldn't take the ceramic floor tiles, so replaced that too. Floor finished, but walls still left to tile and then I can eventually fit the plumbed in bits. So the DET project probably won't move forwards until after Christmas. And my newly re-purchased SE5A is in lockdown in Wales, so that won't be arriving for some time yet :cry:
Anyhow, I've still been buying bits for when I have some free time, such as Comma running in oil, NGK plugs and a pair of Fram oil filters. To try and keep things nice and neat, I've also bought a fuse and relay box for connecting in the DET loom. I'll also use this for the fuel pump and cooling fan relays. And..... having used up 90 of the last box of Jubilee Clips, I ordered another 100 (I think these are a bargain. £37.50 delivered).
Post by swoakes » Sat Oct 24, 2020 1:02 pm
Surely a car purchase is essential travel :!: :D
Post by Corky » Sat Oct 24, 2020 1:07 pm
:lol: I’d like to think so Steve :mrgreen:
Post by Corky » Sat Oct 24, 2020 1:08 pm
Funnily enough the guys that came to pick up the Honda last week came from the Scottish central belt :wink:
Post by efi_sprintgte » Sat Oct 24, 2020 1:31 pm
Have you get a link where to purchase that jubilee collection?
