Has thanked: 286 times
Been thanked: 226 times
Corky's Scimitars & S2K
Post by Corky » Mon Aug 19, 2019 1:05 pm
CNHSS1 wrote:
Mon Aug 19, 2019 12:24 pm
Worth buying genuine Ford or at least known make CVs, 'Hi- Quarity' ebay jobbies are crap :lol:
Hahaha so they are..... in my defence it was the only one I could get delivered next day. But I shan’t make that mistake again. The consensus was that the ones sold by J&R on fleebay are good (I had those fitted originally, and they’re what Jim had fitted to Snotty), so I’ll order a couple of those.
Thanks for bringing another one along Craig. Andy was making some fuss about not being able to drive Snotty home with a missing CV :lol:
Has thanked: 420 times
Been thanked: 352 times
Post by CNHSS1 » Mon Aug 19, 2019 4:07 pm
Kids eh? No imagination :lol:
Has thanked: 74 times
Been thanked: 689 times
Post by philhoward » Mon Aug 19, 2019 5:21 pm
Considering the other junior King had borrowed my trailer to take another poorly SS1 back, the backup option had been removed as well :mrgreen:
Post by Corky » Fri Sep 06, 2019 4:34 pm
Hopefully I'm better prepared for Blyton this weekend than I was for Curborough. I'll now be running four tyres of the same diameter 195/45/15, the correct wheel cylinders (22mm), and I'm hoping a slightly straighter chassis after some tweaking with Craig's ports power hydraulic thingy. I still need to sort the sill out, which I think will require the removal of the lowered floor (a job for the winter I think). I also need to fit the poly bushes to the new OSF wishbone, as it still has the factory fitted rubber ones (I just ran out of time). I've also had the CV joint off again, and given it a generous dollop of CV grease.
Those of you who've looked under the car will know that the flat plates between the chassis rails were slightly V shaped after the crash. They have now been pulled straight.
BEFORE:-
AFTER:-
Has thanked: 36 times
Been thanked: 49 times
Post by nickkeyser » Fri Sep 06, 2019 6:02 pm
Excellent! What rounds are you doing after Blyton?
SSSC Champion 2019
SS1 CVH 1600Ti
Has thanked: 35 times
Been thanked: 159 times
Post by gtcse8 » Fri Sep 06, 2019 6:59 pm
Bloody Hell Steve
It didn`t look TOO big a hit to have actually moved the Chassis inwards to bend the lower plates :cry:
EX SST 1800Ti
Post by Corky » Fri Sep 06, 2019 7:33 pm
Not sure whether to do Goodwood or Combe :?
Bloody Hell Steve
It certainly felt like a big hit :lol: Chassis movement surprised me too, but luckily it was reversible :D
Has thanked: 153 times
Been thanked: 1043 times
Post by scimjim » Fri Sep 06, 2019 7:41 pm
At the front there’s a crossmember and the gearbox mount but there’s only a couple of flat plates behind that, I’m not surprised they buckled from that sideways impact.
Benc
Has thanked: 93 times
Been thanked: 51 times
Post by Benc » Fri Sep 06, 2019 8:45 pm
Combe is full entry closed at present.
Has thanked: 101 times
Been thanked: 151 times
Post by reliant-reviver » Sat Sep 07, 2019 2:02 pm
As you already suggest Steve, it's likely your seat rails that transmitted the force to move the centre section. Was your method of reversal just pressing the plates up, or pushing the main rail out?
By comparison this is what my seat rails did on VTO when it crashed at curbs. You can see the upward deformation of the rail. The centre section was unaffected, I know this because I actually cut the plates out and welded one into another chassis as a repair section.
And for interest, here's some of Reliant earliest thoughts on that part of the chassis.
Chassis centre webs.JPG (84.65 KiB) Viewed 856 times
Post by Corky » Sat Sep 07, 2019 8:56 pm
I pulled the rails apart which almost straightened the plates too. A little direct pressure on the plates finished it off nicely.
Post by Corky » Tue Sep 24, 2019 2:54 am
I'm planning on a mild power hike for next season. So does anyone have a CA20 inlet manifold that they'd be willing to sell?
ca20 itake.jpg (11.98 KiB) Viewed 683 times
Dcrosby13
Has thanked: 30 times
Been thanked: 79 times
Post by Dcrosby13 » Tue Sep 24, 2019 7:47 am
When I last asked that question I ended up buying one from America and have it shipped in I think it came to about £180 including import duty, join the CA20E group on Facebook and put a wanted post up.
I break stuff...... :w
Dcrosby13
Post by Dcrosby13 » Tue Sep 24, 2019 9:09 am
Does look prettier than the standard intake too :) you will need to modify the stock water suction pipe too as it fouls the inlet, we have deliberately left it off until the standalone has gone in because we then dont have to bother with the majority of the emissions junk and cold idle etc
image hosting
Post by CNHSS1 » Tue Sep 24, 2019 12:04 pm
Thy pop up for pennies on US sites on FB Steve, the CA20 is pretty unloved stateside, just the hassle of getting it sent over
EDIT
Didnt spot Darryls post! :oops:
I imported 3 x iirc, cost of shipping and duty split 3 x ways made it slightly less costly but not much, think we paid 150 quid each in 2004/5
