LRP 335E Sprint Coupe
turbster
Post by turbster » Sun May 10, 2020 10:01 pm
Back to the future!! We have an Essex engine again, aaand a T5 box.. The stainless headers are being designed and made, the axle is nearly done... so we’re finally getting there 8)
LRP 335E SE4a
XRF 976H SE5
www.gtevolution.co.uk
Post by efi_sprintgte » Sun May 10, 2020 10:15 pm
84 pages on this thread... :lol: :roll:
turbster
Post by turbster » Sun May 10, 2020 10:33 pm
It’s entertaining if nothing else!!?? :lol:
LRP 335E SE4a
XRF 976H SE5
turbster
Post by turbster » Mon May 11, 2020 7:02 pm
Decided to get it in the car before I went home
tonight.. Looks a bit lost in there!!
LRP 335E SE4a
XRF 976H SE5
Post by CNHSS1 » Mon May 11, 2020 8:45 pm
I have a fiver that says he pulls it out, and fits a milk float motor or a steam engine :lol:
turbster
Post by turbster » Mon May 11, 2020 9:45 pm
Building a 3.4 for this, milk float motor going in something else :lol:
LRP 335E SE4a
XRF 976H SE5
Post by CNHSS1 » Mon May 11, 2020 9:48 pm
I win, i win!! Its coming out :lol: :lol:
Post by DARK STAR » Mon May 11, 2020 10:00 pm
There is room to fit two Essex engines, is there anything in the rules against that?
Post by CNHSS1 » Mon May 11, 2020 11:05 pm
Yep, gravity, 2 x essex will bend the space time continuum
turbster
Post by turbster » Fri Jul 24, 2020 6:44 pm
Big push to get this back together for... absolutely no reason unfortunately :lol:
At least I can have a drive on the road and get it sorted in good time for next season.
Rather than just build up the new axle, I decided to add the Quaife ATB diff, 3.77 CWP, full set of bearings/seals, disc conversion and a new watts linkage drop plate complete with new rose jointed arms :lol:
Unfortunately losing the extended bottom shock mounting point and reducing the angle of the shocks has resulted in a less than ideal ride height 🤦🏻‍♂️ I’m hoping flipping the top mounts and getting some shorter springs will sort it rather than having to get a pair of shorter shocks too..
LRP 335E SE4a
XRF 976H SE5
Post by DARK STAR » Fri Jul 24, 2020 9:26 pm
Just looking at the photos so I may be misinterpreting the layout.
Have you changed the top shock mountings to get more travel, or just to have a more direct action ?
One thing puzzles me, why have you mounted the watts linkage so low, and with asymmetric arms ?
Have you rearranged the radius arm mountings to prevent axle tramp ?
It looks beautiful but I just wondered ...
Post by Old and Slow » Fri Jul 24, 2020 9:31 pm
Correct me if I'm wrong but I thought the watts linkage arms should be horizontal when the suspension is in the "neutral" position?
Isn't there a restricted range of up-and-down movement that will be kept correctly aligned?
If so it perhaps the plate needs reversing so the pivot point is central to the diff rear cover.
Post by efi_sprintgte » Fri Jul 24, 2020 9:39 pm
The Watts will be correct when the ride height is sorted.
Cracking work Mr.T
turbster
Post by turbster » Fri Jul 24, 2020 9:48 pm
Cracking work Mr.T
What James said... When I correct the ride height (by about 4”) all will be aligned, just posted the pics to show how ridiculously it was 💁🏻‍♂️
LRP 335E SE4a
XRF 976H SE5
Post by efi_sprintgte » Fri Jul 24, 2020 9:51 pm
What about raising the top shock mount? You can do a long brace across the chassis at the same time.
