GOX 913W GTC joins the yellow fleet.
superleggo
Re: GOX 913W GTC joins the yellow fleet.
Post by superleggo » Wed Jun 28, 2017 10:20 pm
Shoes off for the rest of the project!
Post by AJL Electronics » Sun Jul 23, 2017 3:11 pm
New wheel assembled with the boss that Tony Idle made for me...
A few other odd jobs done, insulation under the dash almost complete, aux fuse box installed with output wiring and the ventilation tee refitted.
I hurt my back again from being upside down in the footwells!
One other job ticked off was to replace the driver's side wiper wheelbox again. I had been supplied with two passenger ones with different part numbers. It could have been worse though, the driver's side is by far the easiest because you can get to it and see it with the dash out. I took the time to gasket and seal it too.
Post by AJL Electronics » Tue Aug 01, 2017 8:41 am
Last weekend I spent some time sorting wiring and boot area illumination. Then my attention turned to the carpets and I managed to get the bulkhead area fitted properly.
Post by AJL Electronics » Sun Oct 01, 2017 3:02 pm
Had a few hours to play with the project today, I fitted the centre tunnel carpets, glued them down, fitted a spacer under the gear shift, then after I fitted the centre console etc realised that I didn't actually need it and so took it all back out again! Then I found that for some reason there were no Lokuts or fixing holes for the front console bracket, so had to fit those. Afterwards I did a bit of a mockup of the panels...
simmit
Post by simmit » Sun Oct 15, 2017 8:01 pm
AJL Electronics wrote:
Mon May 22, 2017 10:03 pm
It isn't the bulb so much as the bowl and lens. I have found Cibies to be fine, Wipac Quadoptic not bad. Looking at the pattern on the wall, it looks fine.
Any further update on the LED bulbs? Have you tried them on the road yet?
Post by AJL Electronics » Sun Nov 05, 2017 5:26 pm
Not too much to report, with customer vehicles I have not had much time for my own jobs.
I obtained and fitted some two position switches for the seat heaters and fitted them to the centre console, together with a suitable wiring loom.
Improved the wiring to the power socket and made provision for another at the back of the console.
Made the handbrake gaiter and cut a piece of carpet to fit around the gearshift housing.
Upholstered the sides of the dashboard because it looked silly against the cream. That took some time, so all I have done since is to fully install the dash top.
Post by AJL Electronics » Fri Nov 30, 2018 10:38 am
A whole year has gone by? Wow!
Nothing much to report. The car is sitting in storage at the moment while I try to get a space between customer's repairs. Not really that much left to do apart from the interior and hood, so I am hoping to show it at Curborough this next year.
Post by AJL Electronics » Fri Feb 01, 2019 2:49 pm
Post by AJL Electronics » Fri Feb 01, 2019 2:50 pm
MikeT
Post by MikeT » Sat Feb 02, 2019 4:48 pm
Lovely job!
guybetts
Post by guybetts » Sat Feb 02, 2019 5:23 pm
Nice colour.
Update for the register please :D
Guy
GTC Registrar
Rattling
Post by Rattling » Sat Feb 02, 2019 6:03 pm
Very nice colour !
Colin
1800 Ti
Post by gtcse8 » Sat Feb 02, 2019 6:34 pm
Andy is that your work?, didn't know you had a spray booth :?:
Post by AJL Electronics » Sat Feb 02, 2019 6:37 pm
That was a favour somebody owed me. I can do that sort of work but only in the summer as my booth is inflateable and only heated by fan heaters! I still have availability of a proper one via subcontract to him.
Details and some of my work in the later pages of this thread... http://www.scimitarweb.co.uk/sgwrs/view ... th#p429658
Last edited by AJL Electronics on Sat Feb 02, 2019 6:47 pm, edited 2 times in total.
Post by AJL Electronics » Sat Feb 02, 2019 6:39 pm
Nice colour.
Guy
Errrm, it is the same car GOX 913W! The painter recently gave me his photos of the job he did a few years ago, so I uploaded them to the project thread.
Colour is a Ford cherry red which is also known as Nightfire as used on some of the later three wheelers (and BL vehicles).
