GOX 913W GTC joins the yellow fleet.
drcdb15
Re: GOX 913W GTC joins the yellow fleet.
Post by drcdb15 » Thu Jun 01, 2017 10:26 am
AJL Electronics wrote:Middlebridge electrics are just the same as a 6b, as far as the headlamps go. Dim dip may cause the bulbs to flash if in that mode but just disable it!
Thanks for that. As I've got the lamps out at present to tackle the blowers I will try the LEDs as well. Cheers!
Chris
drcdb15
Post by drcdb15 » Thu Jun 01, 2017 6:49 pm
Sorry, a bit of a thread hijack I know, but one last query on the LED lights - There seem to be literally thousands of options for this conversion on fleabay - any particular reason for your specific choice? Thanks
Chris
Post by AJL Electronics » Thu Jun 01, 2017 7:06 pm
Not really any firm reasons apart from perceived confidence in the seller and good spec devices.
drcdb15
Post by drcdb15 » Thu Jun 01, 2017 7:11 pm
Thanks. I've bought LEDs in the past for the dash and sidelights etc for other cars, so I know quality can be flaky at times, so I'll go with your experience and blame you when it all goes wrong... er, I mean... "if" ... :lol:
Chris
Post by AJL Electronics » Mon Jun 05, 2017 4:32 pm
Not much achieved this week. Wired up the centre panel and fitted LED illumination to the switches and instruments.
Oxymoron
Post by Oxymoron » Mon Jun 05, 2017 5:53 pm
Looking good!
Only a couple of my switches illuminate, so I guess I need to replace the bulbs!....Are LED's a straight swap?
Jez
1979 SE6a Automatic power steering! SOLD
Post by AJL Electronics » Mon Jun 05, 2017 6:32 pm
You can put LEDs in as a direct swap, but I graft 3mm wide angle LEDs into the switch itself, which gets rid of the irritating bulbholders that always ping off etc.
The fog lamp switch was drilled 3mm and a 3mm flat top LED inserted, so as to get rid of the afterthought indicator at the bottom.
Post by AJL Electronics » Tue Jun 06, 2017 10:53 am
A word of warning... I bought a pair of new switches described as Scimitar fit. Unfortunately they are actually Triumph TR7 switches. The logo is wrong, not that it matters and the translucent window behind the logo is missing, meaning that they do not illuminate. I have used the (expensive) innards in some original shells to overcome it.
Post by Roger Pennington » Tue Jun 06, 2017 7:20 pm
AJL Electronics wrote:You can put LEDs in as a direct swap, but I graft 3mm wide angle LEDs into the switch itself, which gets rid of the irritating bulbholders that always ping off etc.
That's coming along nicely! :D
When you've replaced the switch illumination with LEDs, are they cool enough to allow you to block off the holes where the old bulbholders went, as one of the problems with the switches is dirt getting in through the bulbholder holes?
Post by AJL Electronics » Tue Jun 06, 2017 8:44 pm
Yes Roger, I have covered the holes with furry loom tape for now.
superleggo
Post by superleggo » Tue Jun 06, 2017 11:01 pm
Andy
I have only just come across this tread and read it front it back. great work I will follow your progress with great interest.
Thanks for the inspiration
Post by Roger Pennington » Wed Jun 07, 2017 11:07 pm
AJL Electronics wrote:Yes Roger, I have covered the holes with furry loom tape for now.
This may be a sign of my electrical innocence, I've never encountered "furry loom tape" before, only the smooth, shiny, non-sticky, variety.
Post by philhoward » Thu Jun 08, 2017 5:59 am
Post by Roger Pennington » Thu Jun 08, 2017 11:28 am
Hmmmm - thanks Phil, I always thought the main advantage of "proper" loom tape was that it had no adhesive, so your loom doesn't go into a horrible sticky mess over time? It seems a bit odd to combine adhesive and a furry cloth back, which will presumably overlap each other in use? Or am I missing something? (ussually the case with electrics! :oops: )
Post by philhoward » Thu Jun 08, 2017 11:31 am
Modern car looms use the furry stuff although I can't think of the exact reason (probably to stop random noises in the cabin as much as anything), plus it's a bit more resilient to damage.
