G97 - zetec inside
G97 - zetec inside
Post by scimjim » Sat Aug 01, 2020 3:18 pm
Mocked up the adaptor plate with manifold fitted - also checked the injectors and loom (removed the plastic cover for clearance)
Then I did some CAD work to make a plate that I can mount the coil pack on as the inlet wants to occupy the space it would normally be in (on the back of the engine)
And loosely fitted
G97 - zetec inside
Post by philhoward » Sat Aug 01, 2020 3:30 pm
I’m guessing that adaptor plate pulls the upper plenum in a bit closer than the current one?
G97 - zetec inside
Post by scimjim » Sat Aug 01, 2020 8:43 pm
It does yes, but it was the plastic surround on the Ford loom that was touching the upper section so I just removed it and will either tape it or use a split conduit.
G97 - zetec inside
Post by scimjim » Mon Aug 03, 2020 8:00 pm
Just for my reference - the standard water pump needs to rotate anti-clockwise, so either mount an idler pulley top right like this:
Or fit a reverse direction impeller and run it clockwise
Obviously, one needs a ribbed pulley, the other needs a smooth pulley.
The Escort Cosworth power steering pump pulley is of the ribbed variety and a 3 bolt fixing with the same PCD - sounds cheap? :D
G97 - zetec inside
Post by efi_sprintgte » Mon Aug 03, 2020 8:19 pm
There’s not a lot of drive on the water pump in the top configuration
G97 - zetec inside
Post by scimjim » Mon Aug 03, 2020 8:27 pm
Agreed, I’d like to see the idler pulley a lot lower down. Billet reverse impellers are about £60 but I think I’ll look at making an idler layout myself first.
G97 - zetec inside
Post by efi_sprintgte » Mon Aug 03, 2020 8:48 pm
Yeah drop that idler pulley down and job jobbed (clearance permitting)
G97 - zetec inside
Post by scimjim » Mon Aug 03, 2020 9:05 pm
That DA pulley is £45 and much lower - reckon I could make that :D
G97 - zetec inside
Post by philhoward » Mon Aug 03, 2020 9:36 pm
What’s the PCD of the water pump pulley? I’ve collected a few in the course of my supercharger belt run design. There’s also a 4-rib, 3 bolt one on the MX5 engine..
G97 - zetec inside
Post by scimjim » Mon Aug 03, 2020 9:38 pm
Not sure (and can’t find it on google) - will check at the weekend :D
G97 - zetec inside
Post by philhoward » Mon Aug 03, 2020 9:38 pm
Don’t forget you can get double faced polyvee belts allowing you less wrap (going CCW) and still get enough power transfer.
G97 - zetec inside
Post by philhoward » Mon Aug 03, 2020 9:39 pm
G97 - zetec inside
Post by MikeyBikey » Mon Aug 03, 2020 10:07 pm
My scimega has a very short kiss on the water pump, similar to the above. Seemed to work fine, I presume as it’s only pushing water, the water resistance is low compared say to an alternator,
G97 - zetec inside
Post by scimjim » Sat Aug 08, 2020 8:59 pm
Rather than adding weight, I’ve decided to go with the reverse impeller (having found one only a few quid more than Cost of the the idler and bracket).
Today, I threw some primer at some of the panels
G97 - zetec inside
Post by scimjim » Sat Sep 05, 2020 8:37 am
after some thought, I decided that I shouldn’t be adding weight, so £55 later a reverse direction water pump impeller has arrived 😎
