G97 - zetec inside
G97 - zetec inside
Post by scimjim » Sat Jun 06, 2020 8:26 pm
Picked up an adaptor plate for the zetec to take an RX8 box the other day so thought I’d mock it up on a spare block. Cut away a bit for the starter too.
G97 - zetec inside
Post by nickkeyser » Sun Jun 07, 2020 8:07 am
This is interesting! Have been looking at stronger gearbox compared to the type 9, but haven’t looked outside the ford options yet - Tremec T5 (expensive) or MT75 (big! But lighter than a Type 9).
SSSC Champion 2019
SS1 CVH 1600Ti
G97 - zetec inside
Post by CNHSS1 » Sun Jun 07, 2020 9:52 am
MT75 was in my TVR, gearchnge was poor compared to type 9, more 'rifling through the cutlery drawer' than 'rifle bolt' action of type 9 with quaife gearlever
G97 - zetec inside
Post by philhoward » Sun Jun 07, 2020 10:00 am
Even after getting rid of the rubber bushes in the housing and linkage?
G97 - zetec inside
Post by scimjim » Sun Jun 07, 2020 10:12 am
Next step is to drop it in a chassis to check for clearance. The gearchange is more like a type 9 with Quaife.
Playing with ratio calculator to see if there’s any advantage in carrying an extra gear around. Same rpm, diff and tyres for direct comparison. Looks like the 5 speed wins?
Type 9
RX8 5 speed
RX8 6 speed
G97 - zetec inside
Post by philhoward » Sun Jun 07, 2020 10:18 am
Looks nice from a ratio point of view on the 6 speed? As daft as it seems (adding an extra gear) you’ll probably end up changing gear less as you’ll probably find a single gear to go further? You could probably do 80% of Curborough in the new 3rd gear alone?
G97 - zetec inside
Post by scimjim » Sun Jun 07, 2020 10:28 am
You have an even lower geared first though, I think if you can take off in second it might be a good 5 speed box but I need to weigh them both.
G97 - zetec inside
Post by philhoward » Sun Jun 07, 2020 10:30 am
1st is only very slightly lower than the type 9 but as you say, the lower second could make it worthwhile to start with.
Or swap you for a 3.62 :mrgreen:
G97 - zetec inside
Post by philhoward » Sun Jun 07, 2020 10:31 am
TBF I’ve come to the conclusion a second set of wheels and tyres with differing rolling radius is quicker to change than a diff :mrgreen:
G97 - zetec inside
Post by scimjim » Sun Jun 07, 2020 10:31 am
I have a spare 3.62 CWP to attach my Quaife to thanks :D :D :D
G97 - zetec inside
Post by scimjim » Sun Jun 07, 2020 10:33 am
So looking at a diff change, this is the 6 speed with a 3.62 - very nice 8)
G97 - zetec inside
Post by philhoward » Sun Jun 07, 2020 10:35 am
205/55x15 tyres?
G97 - zetec inside
Post by scimjim » Sun Jun 07, 2020 10:37 am
I just put some numbers in for a comparison, can’t actually remember what I’ve got fitted as I’ve just bought new tyres for the Merc, looking at tyres for DJ the other day, new tyres for 8 ball and “not diesel” :D
G97 - zetec inside
Post by philhoward » Sun Jun 07, 2020 10:38 am
205/55x15 sounds like what you’ve got on 8 ball TBH?
G97 - zetec inside
Post by scimjim » Sun Jun 07, 2020 10:41 am
Probably :D at least I didn’t put 225/45 r17 in :D
Should be 195/50x15. 8 ball has 205/60x15.
