Occupation during my holidays
Eric2205
Post by Eric2205 » Tue Dec 18, 2018 8:36 am
Hello,
As I have a few holidays between Christmas and New Year I would like to work on my Scimitar:
I have to change the brake discs and I would like to know the size of the socket to unscrew the "50764B, Slotted nut, stub axle shaft"
Otherwise I was surprised to find spacers on the front wheels, there are none on the rear wheels. So is it on all Se5a?
I would also like to adjust the rockers, I have never done but somebody told me "it's not complicated !" Any advice for that?
What are the spacings for the intake and the exhaust?
How to recognize the intake and exhaust valves?
thank you in advance
Regards Eric
Has thanked: 189 times
Been thanked: 1274 times
Post by scimjim » Tue Dec 18, 2018 9:33 am
Spacers are only standard with the optional PA alloys.
I can’t remember the size of the hub nut but it’s imperial.
Rocker numbering is from front right to rear right, then front left to rear left - same as cylinder numbering. The exhaust valves are inline with the exhaust manifold.
Post by scimjim » Tue Dec 18, 2018 9:37 am
It’s all in the manual but here’s the relevant page
Number three cylinder..........valve 6 (Inlet)..........valve 12 (Exhaust).......Number six cylinder
.....................................valve 5 (Exhaust).......valve 11 (Inlet)...................................
Number two cylinder..........valve 4 (Inlet)..........valve 10 (Exhaust)..........Number five cylinder
....................................valve 3 (Exhaust).......valve 9 (Inlet).......................................
Number one cylinder..........valve 2 (Inlet)...........valve 8 (Exhaust)..........Number four cylinder
...................................valve 1 (Exhaust).......valve 7 (Inlet).......................................
.......................................(front of engine)............................................................
Eric2205
Post by Eric2205 » Tue Dec 18, 2018 10:05 am
Hi,
Thank you very much for all the informations :D :D
Been thanked: 148 times
Post by Oaksey » Tue Dec 18, 2018 10:40 am
The hub nut is 13/16 AF
1973 Beige Se5a Overdrive
1969 Se5
1972 Se5a
2005 Honda S2000
2016 BMW 330d
Has thanked: 81 times
Been thanked: 213 times
Post by gtcse8 » Tue Dec 18, 2018 11:59 am
The nut should be "Loose, and held in place with a split pin.
Hardest bit will be removing the caliper and then the Disc from the hub.
Has thanked: 52 times
Been thanked: 320 times
Post by AJL Electronics » Tue Dec 18, 2018 12:20 pm
I would query "loose" ;-) It should be tight enough to allow a sixteenth of an inch float at the top and bottom of the road wheel.
Eric2205
Post by Eric2205 » Tue Dec 18, 2018 1:20 pm
I have a 13/16 socket
As I own a wolseley and a spitfire I have tools in imperial
I'm agreeing with "Hardest bit will be removing the caliper and then the Disc from the hub."
I have a shock key and a lot of WD40 !!
Eric2205
In the driver's manual I found this passage.
I am surprised by the phrase: "while while the engine is running"
I thought to do this cold engine so as not to burn my hands and it is advisable to do it hot engine
The values to be paid are different from those communicated
You advise me cold engine or hot engine?
Post by scimjim » Tue Dec 18, 2018 2:01 pm
You need the special rocker covers to do it with the engine running - or there will be oil everywhere.
I use 12 & 20 thou cold - just nip them up a little more if any are still rattling when hot.
Eric2205
Post by Eric2205 » Tue Dec 18, 2018 2:10 pm
12 and 20 in ?
Has thanked: 32 times
Been thanked: 134 times
Post by Coupe Racing » Tue Dec 18, 2018 2:19 pm
Thousandth of an inch
Eric2205
Post by Eric2205 » Tue Dec 18, 2018 2:25 pm
Of course :D
Post by AJL Electronics » Tue Dec 18, 2018 2:33 pm
a lot of WD40 !!
You would be better off with penetrating oil. I prefer a 50:50 mix of ATF and Acetone, but otherwise diesel does a good job if you can't get commercial stuff like PlusGas.
Post by gtcse8 » Tue Dec 18, 2018 2:34 pm
I would query "loose" It should be tight enough to allow a sixteenth of an inch float at the top and bottom of the road wheel.
They should NOT need a socket or spanner to undo them is what I meant, that`s why I put "Loose, I suppose I should have said "Finger tight, as the split pin keeps the endfloat correct. :lol:
