Alternative Alternators
Mr Bridger
Post by Mr Bridger » Mon Sep 24, 2018 10:59 am
Last night whist driving home in the dark the red ignition light came on. Stupidly I didn’t think to check what the volt meter was reading, however the light did come on & go off irregularly. When I switched the ignition off the red light stayed on.
So, I suppose it is time for a new alternator. However, on other cars I have had bad experiences with ‘new’ or overhauled Lucas ACR units, with the diode packs going after a short time. It there a suitable replacement that people fit to their Scimitars from a modern that I could pick up from a scrapyard ?
1975 SE5a - Daily Driver
1970 Triumph Vitesse
1972 VW Camper Van
1965 Sunbeam Tiger
1997 Mk1 MX5
Has thanked: 186 times
Been thanked: 1264 times
Post by scimjim » Mon Sep 24, 2018 11:32 am
The A127 range has an easily replaceable (and cheap) diode and brush pack?
Has thanked: 224 times
Been thanked: 52 times
Post by willholderogri » Mon Sep 24, 2018 12:04 pm
I will second that try and get 55 Amp and upwards
Mr Bridger
Post by Mr Bridger » Mon Sep 24, 2018 1:51 pm
How easy is easy? I'm ok with spanners, and even not too bad with a spray gun, but generally it's a good idea to keep me away from wires and soldering irons.....
1972 VW Camper Van
1965 Sunbeam Tiger
1997 Mk1 MX5
Post by scimjim » Mon Sep 24, 2018 2:54 pm
3 screws I think
eBay photo of diode/brush pack:
And back of alternator:
Has thanked: 52 times
Been thanked: 318 times
Post by AJL Electronics » Mon Sep 24, 2018 4:20 pm
Fit an A127 and you will not be worrying about diode packs and regulators for quite some time.
Mr Bridger
Post by Mr Bridger » Mon Sep 24, 2018 8:37 pm
I've had a look and my car has a Lucas LRA 101 alternator fitted. I take it that's different to the A127?
Interestingly there is a choice of A127 alternators on the market; a far eastern version for 50 quid and an Italian made one for £170! I wonder which one would be the most reliable?
1972 VW Camper Van
1965 Sunbeam Tiger
1997 Mk1 MX5
Post by willholderogri » Mon Sep 24, 2018 9:09 pm
Most 1980s fords used them I bought a new one last weekend at an automobile for my car
Mr Bridger
Post by Mr Bridger » Tue Sep 25, 2018 7:08 am
Thanks for the assistance chaps, I've ordered an A127 (the cheap version!).
1972 VW Camper Van
1965 Sunbeam Tiger
1997 Mk1 MX5
Diyhell
Has thanked: 108 times
Post by Diyhell » Tue Sep 25, 2018 8:45 am
Thinking of this myself also...can I just confirm I need the RH (Right Hand) version?
SE6a needing lots of work...
Has thanked: 80 times
Been thanked: 212 times
Post by gtcse8 » Tue Sep 25, 2018 9:59 am
The BRAND NEW 75/80A ones advertised for boats are Brilliant :lol: , I have fitted quite a few and apart from the Extra wire to keep the battery topped up, which you don't have to fit if you don`t want to, which supplies 14V all the time to the battery even at low revs. :wink:
292737128400
Post by gtcse8 » Tue Sep 25, 2018 10:05 am
Nope, you need the Left Hand version.
BUT it`s just Three nuts to undo to swivel the front mounting round to make it fit if a RH version is bought.
Diyhell
Post by Diyhell » Tue Sep 25, 2018 10:16 am
Thanks Mark - that's one winging it's way to me...
BTW, I noted the recommendation on Ebay to check the wiring grade. Will the standard wiring can cope?
David Tew
Has thanked: 26 times
Been thanked: 69 times
Post by David Tew » Tue Sep 25, 2018 10:27 am
Mark beat me to the reply! :wink:
The attached will help explain the fitting orientation.
Alternator fixing.jpg (96.69 KiB) Viewed 1966 times
Post by gtcse8 » Tue Sep 25, 2018 8:19 pm
YES, standard wiring should be ok. :D
BUT :idea: I ALWAYS run the extra connector from the back of the boat alternators using a fairly thick wire, 6mm seems to work ok, :!: straight to the Positive on the battery because it supplies 14v at low revs therefore charging the battery at tickover. :lol:
