Vertical Link SE5, SE6A, SE6B
SJM
Post by SJM » Sun Nov 10, 2019 2:41 pm
Does anyone one know please what the differences are between the front suspension vertical links on the SE5, SE6A & SE6B?
Thanks.
Stuart
Post by Coupe Racing » Sun Nov 10, 2019 3:10 pm
The stub axle for a start
SJM
Post by SJM » Sun Nov 10, 2019 5:09 pm
The axle is not part of the link; it is a separate component.
Post by gtcse8 » Sun Nov 10, 2019 5:19 pm
Stuart there are at least Four different types of Vert links.
They take different sized stub axles for a start, which is what CR was pointing out.
So therefore the tapered hole is different.
Some also have a different size of inner bearing/grease seal shoulder.
They will all have the same lower trunnion machined surface for LH and RH, and the top hole will accept all standard top ball joint.
The are mostly ALL machined from the same casting so don`t go on the casting numbers.
Post by scimjim » Sun Nov 10, 2019 6:39 pm
I don’t think any of the changes to the vertical link coincide with model changeover points.
It’s the outer bearing that changed size Mark, are you sure the tapered hole changed size?
Post by gtcse8 » Sun Nov 10, 2019 7:52 pm
Deffo Jim
Ask me how I know?. :W
Not near my emporium at present but as I reman stub axles I know they are different.
Will take some pics tomorrow to demonstrate. :drum:
Dennis Nicholas has talked extensively on the inner bearing and grease seal shoulders. :w
Post by scimjim » Sun Nov 10, 2019 8:00 pm
Yes, the inner grease seal is different on later uprights (discussed long before Dennis removed his :D ) but I don’t recall discussing any other differences on here?
Post by gtcse8 » Mon Nov 11, 2019 8:00 am
The Taper on the stubs have different diameters.
There are THREE different sizes of stubs to take different bearings.
First & last stubs.jpg (87.97 KiB) Viewed 983 times
Only Two shown here.
OR These.
Early link last stub fitted.jpg (140.64 KiB) Viewed 981 times
Early link mid stubb fitted.jpg (153.74 KiB) Viewed 981 times
Later stub .750 outer.jpg (137 KiB) Viewed 983 times
Later stub 1inch inner bearing.jpg (131.04 KiB) Viewed 983 times
Last type stub 34inch outer.jpg (129.76 KiB) Viewed 983 times
Last type stub 27mm inner bearing.jpg (129.67 KiB) Viewed 983 times
Then we have AT LEAST Three combinations of Vertical link :w
Latest vertlink with early stub fitted.jpg (180.77 KiB) Viewed 983 times
Late vert with early stub.jpg (135.54 KiB) Viewed 983 times
Late combo no spacer.jpg (163.69 KiB) Viewed 983 times
Late combo with spacer.jpg (172.46 KiB) Viewed 983 times
SJM
Post by SJM » Tue Nov 12, 2019 7:13 pm
Thanks Mark & others for all the info!
Stuart
