Coupe/GTE Front shock fitted length
Been thanked: 141 times
Post by Oaksey » Sat Jun 15, 2019 3:07 pm
Does anyone know what the fitted length of the front shocks is for geometry setup purposes?
1973 Beige Se5a Overdrive
2005 Honda S2000
2014 BMW 330d xDrive
Has thanked: 77 times
Been thanked: 704 times
Post by philhoward » Sat Jun 15, 2019 8:34 pm
Possibly oddly I think the details of a “length of box section steel with 2 holes” is in the SE6 manual? Pretty sure Roger Pennington has posted the details in the past?
Has thanked: 153 times
Been thanked: 1050 times
Post by scimjim » Sat Jun 15, 2019 8:36 pm
I had a look in the 5 and 6 books and couldn’t find any reference?
Post by Oaksey » Sat Jun 15, 2019 8:41 pm
I had a look too but couldn't find it. I may have to make an educated guess for initial setup then once the new shocks finally arrive, put it on the ground and measure it up
2005 Honda S2000
Post by scimjim » Sat Jun 15, 2019 9:00 pm
It does say add 150 lb to both front seats before checking alignment IIRC.
Post by Oaksey » Sat Jun 15, 2019 9:56 pm
I noted that bit from one but sort of ignored it as its the straight six I'm doing and there were no official measurements so I'm going to have a bit of a play around and see what works best
2005 Honda S2000
Been thanked: 559 times
Post by Roger Pennington » Sun Jun 16, 2019 11:06 am
Yes, it's in the Se6/6a Manual, and it looks like this:
Post by philhoward » Sun Jun 16, 2019 11:15 am
That’s the animal...
Dennis Nicholas
Has thanked: 64 times
Been thanked: 35 times
Post by Dennis Nicholas » Wed Jun 26, 2019 11:21 pm
That is for an SE6 fully loaded simulation? How often does one drive with those conditions. I set my spring seats with one passenger at lower wishbones parallel to ground so eye to eye slightly smaller than the 13.64 inch of the setting bar above. (i.e. only part loaded)
Dennis Nicholas(RSSOC)
