TR6 Wheel nuts
rebel alliance
Been thanked: 60 times
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 9:48 pm
Cheers i might give Rimmers a call, spitfire studs could be 1/2 ?...time i buy tyres this is getting to be an expensive exercise 😕..should add the nuts have to hold the TR plastic centres on which is why just a normal nut won't do
Has thanked: 64 times
Been thanked: 632 times
TR6 Wheel nuts
Post by philhoward » Mon May 20, 2019 10:02 pm
You’ll probably find standard GTE steel wheel nuts will do that..
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 10:49 pm
Maybe but i think the sleeve part is to big for the tr plastic centres...i could get Bill to make some custom ones if i have to
Dennis Nicholas
Has thanked: 49 times
Been thanked: 32 times
TR6 Wheel nuts
Post by Dennis Nicholas » Tue May 21, 2019 9:01 am
A thing to bear in mind with TR there is the TR6 and the TR GT6. Very similar front suspension but some significant differences (anti roll bar link for example....GT6 may fit Scim? but TR6 is different.)
So maybe there are differences in wheel studs between the two.
Dennis Nicholas(RSSOC)
TR6 Wheel nuts
Post by philhoward » Tue May 21, 2019 9:40 am
There's the Triumph TR6 and the Triumph GT6 - not sure how you'd manage to get those confused, though?
GT6 studs are even smaller than TR6 ones (3/8" UNF versus 7/16" UNF), so they won't do either.
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Tue May 21, 2019 9:52 am
I'm just calling Rimmers see what they suggest..if i was not useing the conical wheel centres with the chrome caps i could use any 1/2 unf nut but i need ones to suit those centers with the correct length up to where the plastic washers sit...Basically i need tr6 nuts but with a 1/2 unf thread
TR6 Wheel nuts
Post by philhoward » Tue May 21, 2019 10:05 am
The GTE steels (with fibreglass trims) use a nut with a 60 degree taper that has a collar with a rubber washer to hold the trim on...just the same way as the TR6 trim is held on.
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Tue May 21, 2019 10:46 am
These are a bit smaller holes.i will try some first..i don't want to be tightening up on plastic trims instead of metal
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Tue May 21, 2019 10:49 am
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Tue May 21, 2019 10:53 am
Actually recessed on the scimitar ones
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Tue May 21, 2019 11:16 am
Rimmers useless ,anyone got Bill Brightons email 😊
TR6 Wheel nuts
Post by philhoward » Tue May 21, 2019 12:45 pm
The search is your friend.. http://www.scimitarweb.co.uk/sgwrs/view ... cc#p474972
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Tue May 21, 2019 1:04 pm
Ta😊
TR6 Wheel nuts
Post by philhoward » Tue May 21, 2019 1:41 pm
Was looking for a picture of a GTE on TR6 wheels with trims - found one of Dave Poole’s SE5 and her had centre caps on his:
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Tue May 21, 2019 2:30 pm
Thats looks like a dunlop or wolfrace centre the tr6 ones go over the studs..hence my nut problems 😊
