TR6 Wheel nuts
rebel alliance
Been thanked: 52 times
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 5:35 pm
Anyone know if TR6 wheel studs are the same size and thread as a scimitar...
Has thanked: 137 times
Been thanked: 508 times
TR6 Wheel nuts
Post by Roger Pennington » Mon May 20, 2019 6:04 pm
I'm pretty sure TR6 is a 7/16 UNF thread, so that's a no....
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 6:06 pm
Thats worrying i assumed they would be the same
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 6:11 pm
Anyone confirm the scimitar studs are 1/2 unf forget that just measured one.....ok next question what wheel nuts do i need to put tr6 rims on a scimitar
Has thanked: 130 times
Been thanked: 948 times
TR6 Wheel nuts
Post by scimjim » Mon May 20, 2019 7:49 pm
I don’t think all TR6 are 7/16” - I have a TR6 steel on the coupe and it fitted straight on.
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 8:11 pm
Hrmmmm i have some rims coming tomorrow so i was bidding on some tr6 chrome nuts but seller has no idea of the thread size so i dropped out.A google search seems to suggest tr6 studs are 7/16 as Roger said..
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 8:16 pm
Only info i have is part number 154470 on Rimmers site which i can't get on
Terry H
Been thanked: 47 times
TR6 Wheel nuts
Post by Terry H » Mon May 20, 2019 9:01 pm
That part number on Rimmerbros show Wheel nut at £3.66 each inc vat with no washer. https://rimmerbros.com/Item--i-154470
Regards Terry H
chrisgallacher
Been thanked: 35 times
TR6 Wheel nuts
Post by chrisgallacher » Mon May 20, 2019 9:02 pm
I have a set of TR6 wheels for my Sabre Six, as do one or two others. Studs are 1/2" UNF just like at least the Coupes and SE5s and as Jim says above, the TR6 wheels fit perfectly - mine are not designed for 7/16" studs. That's not to say there wasn't some variant for smaller studs, but I'm not aware of them.
I would suggest stainless rather than chrome nuts. Chrome will look great for 5 minutes, but in no time the chrome will start to peel once you've tightened and untightened them and they'll quickly look a mess. Bill Brighton (club member on here) on here makes the best stainless wheel nuts and he knows Scimitars so you'll know they'll fit and last, or if you want something a little cheaper without a mirror finish then I bought the ones below from ebay for everyday/rally use. This was a couple of years ago and the link doesn't work anymore so this is a pic, but I'm sure they're still available. Correct size to fit TR6 wheels to 1/2" UNF studs as used on the Scimitar range:
Wheel nuts.PNG (52.84 KiB) Viewed 450 times
Chris Gallacher
RSSOC Rally Secretary
rally.secretary@rssoc.co.uk
TR6 Wheel nuts
Post by Roger Pennington » Mon May 20, 2019 9:07 pm
Well, This thread on the TR Register TR6 Forum seems to confirm 7/16 UNF for nuts to be used for alloy wheels.
On Rimmer's website here (TR6 alloys), they appear to confirm 7/16 UNF for alloy wheels.
But, on Rimmers website here (TR6 steels), alongside the wheels they list nuts and "studs, for steel wheels only" :shock: They don't mention the thread size - could it be the steels are different? :w (maybe the alloys use the same thread/studs as used to secure the wire wheel hub adaptors????)
chrisgallacher
TR6 Wheel nuts
Post by chrisgallacher » Mon May 20, 2019 9:10 pm
That's odd Roger. My wheels are definitely TR6 steels, they fit and the nuts I linked are correct - I can't speak for alloys.
Chris Gallacher
TR6 Wheel nuts
Post by Roger Pennington » Mon May 20, 2019 9:17 pm
Yes, that's the thing, I *suspect* that what Rimmers are saying is that steels are a different size, and need to have their own dedicated studs, etc. They don't specify the size, but it could well be 1/2, which would tie in with yours and Jim's experience. :)
Has thanked: 50 times
Been thanked: 599 times
TR6 Wheel nuts
Post by philhoward » Mon May 20, 2019 9:29 pm
During that era, steels would generally have taper nuts (I see 60 degree mentioned, which is pretty common) but alloys would generally have sleeve-type nuts such as the Dunlops fitted to the 5a.
I was only aware of steel rims for the TR6 from the factory. That’s not to say you can’t buy alloys off the shelf for them as well we know.
rebel alliance
TR6 Wheel nuts
Post by rebel alliance » Mon May 20, 2019 9:34 pm
Thanks everyone the situation is i bought some nice tr6 steel wheels which with shipping came in at £280..The nuts on ebay with a starting bid of £40 +pp would do but no way of confirming if there 1/2 unf thread..for some reason my internet crashes when i go on Rimmers site.....bit stuck now dont want to buy nuts for £50 it there wrong
TR6 Wheel nuts
Post by philhoward » Mon May 20, 2019 9:37 pm
If they’re TR6 nuts, they’ll be wrong. If they’re GTE steel wheel nuts, you’ll be OK. Also XJ6 with steel wheels, I think?
