Gearbox T5 problems, update to fit RX8 6 speed box
Don Ricardo
Post by Don Ricardo » Sat Oct 20, 2018 4:57 pm
Don Ricardo here, I have major geardox problems, the box is stuck in 1st gear and try as I may I cannot get it out. So after discusion with a local gearbox specialist|||, I have decided to change tack after hearing about a conversion/adapter plate to fit a Mazda RX8 6 speed gearbox. Apparently it's straight forwad as all that needs adapting is the prop shaft. My question is has anyone done this and what are the pit falls if any. So have decided to go Mazda way it appears to be cheaper, RX8 gearbox has arrived as has the adapter plate, trial fits of adapter plte to engine and to gearbox went great, starter moter fits adapter plate, but not gearbox bellhousing, that needs a slight modification, also RX8 bellhousing needs a blanking plate to cover Mazda starter motor hole. Securing bolts required :- M10 x 40 6 of countersink head, M10 x 100 1 of; M10 x 60 7 of hex or allen key head, M10 nylock nuts as required. One good thing the gearbox arrived with the splined prop shaft end as this is 38mm dia and the ford is 34mm so it is required.
Thats as far as I have got, photo's to be added within next few days.
Has thanked: 178 times
Been thanked: 1228 times
Post by scimjim » Sat Oct 20, 2018 8:12 pm
Mine seems to hit the clutch slave cylinder too - apparently there’s a Mazda slave that fits. I went for the 5 speed, ratios look better for the Scimitar.
Post by Roger Pennington » Sat Oct 20, 2018 8:20 pm
Have a look through this thread, lots of info in there :)
BusaPhill
Post by BusaPhill » Sat Oct 20, 2018 9:12 pm
Mazda RX-8 has a electronic speedo.
So you'll need to source something Else.
1980 Dolomite Sprint with RX8-13B power
2005 Mercedes C320 V6 3.0 7speed Auto (Diesel Daily Driver).
Has thanked: 370 times
Been thanked: 181 times
Post by MikeyBikey » Sat Oct 20, 2018 10:50 pm
I also went down this route before doing the omega conversion. I have the 5 speed box, adaptor plate and, both types of prop, scimitar, and rx8. Both props fit the box, but the scimitar has narrower diameter nose. I was on the cusp of having a bush made to press in the back of the Mazda box to take up the extra diameter, then using a standard scimitar / Ford rear oil seal and prop. I mocked it up on a spare Essex, it all fitted beautifully. Standard. Essex flywheel, clutch, pressure plate. I was adapting to cable paddle. There is a method shown on the Facebook site.
Don Ricardo
Post by Don Ricardo » Tue Nov 20, 2018 5:19 pm
Sorry for the delay, have now got a health problem, so having to take things easy for a while. Anyway back to the gearbox, I have used the RX8 yolk and had it reamed out to take the Scimitar UJ (26.89mm), I am now waiting for the clutch kit (3 part) to turn up, then it's assemble the engine and earbox and offer them up into the car, measure the prop shaft and send it off to be modified,(By my calculations the shaft needs to be shortened by 40.50 mm) I have toyed with the idea of having a new shaft made, but so far not had any luck with a supplier here in Spain. So while waitng, over the next week or so I will be changing the Cam gear for an alloy one and also fitting a new distributor with electronic ignition, also a new set of core plugs.
With regards to the speedo drive there is a system(American obviously) using a gps driven unit that connects to your original speedo, so no problem realy, only the cost, it's about 300.00 U$, so that will have to join the list of wait till next year items.
Don Ricardo
Post by Don Ricardo » Tue Feb 12, 2019 8:07 am
Happy New Year to you all. My doesn't time fly , it's now February and I have been out of action on and off for the last 8 weeks, not able to do much, but what I have done has put me further back with the whole restoration of the 5A. While waiting for the clutch I decded to check the front suspension and brakes out. What a shock, upon taking the wheels off I was met with what can only described as a lump of rust, so I seem to be going backwards rather than forward. The whole assembly is now removed and stripped, and a list of parts required made up, the main item being the lower wishbone bracket for the shock and roll bar, which is rotten.
Clutch assembly finally arrived yesterday, but that will have to wait, as front suspension has to be fixed/ refurbished and refitted to make the 5A mobile.
stevecrosby63
Been thanked: 25 times
Post by stevecrosby63 » Tue Feb 12, 2019 10:13 am
slave for a mazda 6 fits nicely...have a look at the rx8 adapter page on facebook
stevecrosby63
Post by stevecrosby63 » Tue Feb 12, 2019 10:20 am
i was going down this route on the 6a but ended up with the ti to sort and darryl ended up selling the car, so i didnt manage to sort it. speedo drive is relatively simple and uses a smiths speedo from a mk 3 xj6 (electronic) so wont look out of place ...i posted all the details on the rx8 page and it may be useful to someone
